LELONG Dynamite C4 Big Stick 7700kv Brushless Motor 2S-3S for 1/10 RC >
Old 04-28-2011, 08:41 PM
aqeel200's Avatar
Default LELONG Dynamite C4 Big Stick 7700kv Brushless Motor 2S-3S for 1/10 RC
Item Description: Dynamite C4 Big Stick 7700kv Brushless Motor 2S-3S for 1/10 RC
Used or New : Used But Practically new used only once
Condition & Age if Used : 9.9/10 practically new and used only once and working fine.
Price : RM 130.00
Negotiable : YES
Reason : TOO SMALL FOR MY APPLICATION
Mode of Delivery : COD, POSTAGE EXTRA
PLEASE PM/SMS ME IF U ARE INTERESTED ON THIS ITEM.
H/P 019 319 2055
COMPATIBLE with all Brushless ESC
ITEM DESCRIPTION
This is a branded Dynamite 540 C4 Big Stick 7700kv 4T-5T Brushless Motor. I bought it new USD57.00 from US + Shipping. Retail selling price is USD75.00. It is the same class and identical to the Castle Creations CM36 7700kv BL motor. Ideal for 2S touring or 2WD 1/10 SC. Overkill for 3S
Bought with the intention to use on 1/10 Touring but I have sold the complete set. Son lost interest in Touring. Tried it on 1/10 SC but could not get a mod-1 correct T pinion for the 1/8 standard 1/10 motor shaft. Mod-1 pinion are 5mm shaft. Test on 4WD SC and it is extremely fast. Decided to let it go because of difficulty in getting the mod-1 pinion 1/8 (3.?mm shaft standard for all 1/10 pinion) for right gearing. This motor is also too small for a 4WD lots of alloy 1/8 SC.
Specs is as follows:-
Motor can size 540, same as the EZRun 5.5T motor
Product Specifications
Type:Brushless
Bearings or Bushings:Two 5 x 11 x 5 Bearings
Voltage:7.2-12v
RPM/Volt (Kv):7700kv
Speed Control:Sensorless Brushless ESC required
Shaft Diameter:36mm
Shaft Diameter w/Gearbox:3.25mm
Attached Thumbnails LELONG Dynamite C4 Big Stick 7700kv Brushless Motor 2S-3S for 1/10 RC-img00055-20110427c41-0805.jpg   LELONG Dynamite C4 Big Stick 7700kv Brushless Motor 2S-3S for 1/10 RC-img00056-20110427c42-0806.jpg
aqeel200 is offline
