JUMP SQUARE ARENA - SALES THREADS
Old 01-04-2011, 09:09 PM
JSA
JSA's Avatar
Default JUMP SQUARE ARENA - SALES THREADS
ORIGINAL PRICE: RM 135.00
NOW SPECIAL OFFER PRICE - RM100 PER SET (TIRES + RIMS @4PCS)
HOTBODIES TIRES / C&Y TIRES
Tech-Bone Tyres
Buggy racers rate our Tech-Bone tyres as one of the best all-around tyres for any condition. Buggy bashers love the Tech-Bone for its massive grip and cool looks. You can't go wrong! These tyres are pre-glued on exclusive Hot Bodies multi-spoke wheels/Dish wheels for low weight and great looks on the track. Soft compound for ultimate grip with good tread life.
Notch Tyres
The Notch Tire is highly acclaimed by buggy racers as one of the best all-around tyre tread designs for straight-line grip with good side bite. You can actually feel the track come apart from under the tyres as you rip out of corners! These tyres are pre-glued on exclusive Hot Bodies dish wheels for good aerodynamic properties, with the added benefit that you can't get rocks stuck in the spokes. Soft compound for ultimate grip with good tread life.
Hot Bodies - Khaos Tyres
HB Khaos tyres have been designed specifically to suit a range of off-road racing conditions, and are perfect for loose dirt, clay, blue groove and damp tracks. They also work great on hard surfaces with a scattering of dust on top.
The tire body has hundreds of wide rectangular lugs spaced around the carcass, providing excellent forward traction and mud-slinging ability to keep the treads clear and the tyre free from dirt build-up. The square sides of the treads give supreme cornering grip for extra confidence in technical track sections. Running down the centre of the tyre is a double row of tread blocks spaced even farther apart for excellent straight-line stability at high speeds. The carcass shape makes it perfect for rutted and bumpy terrain, because the curved sidewall doesn't dig in and cause grip-rolling through too much traction.
RM110 per set (Tires Only x4pcs)
JSA is offline
Old 02-05-2011, 10:40 AM
krizalzul's Avatar
1:8 ?
krizalzul is offline
Old 02-06-2011, 06:06 AM
nightc's Avatar
Nice offer.. Will get some for my SCT once the 17mm hex adapter arrived.
nightc is offline
