CY B6 plus Balancer (2-6S Series)
Old 01-04-2011, 10:21 AM
mizi79's Avatar
Default CY B6 plus Balancer (2-6S Series)
chargery power - CY B6 plus Balancer (2-6S Series) for lipo.
Cond. : 9.5/10 (like new just 2-3 time use)
trade : ship or COD(ipoh area only)
Price : RM90
Contact : 0134308007
details :
The CY-B6 + is an exteremely versatile device.Designed specially for 2 to 6 lipo cells in series.It can detect and balance each cell in a pack while the battery pack is being charge.
It can balance any lithium 2s to 6s battery pack which has a balance connector and nominal voltage of 3.7v per cell.
You can also balance two 3s packs at the same time!
This device works in Stand-Alone mode for when you want to balance packs after flights or while at the field or even after charging.Or you can use this unit while youre charging you packs.
Feature :
Balance while charging.
Balance two battery packs simultaneously
Safety cut -off charging circuit while detecting the voltage of cell is over 4.2v
Automatically detect and indicate battery balance status for any 2s-6s packs
Audio alarm for over voltage
Audio alarm for under voltage
LED dispaly each cell in balancing
Reverse polarity and short circuit protection (input & output)
With special connector conversion Board (CCB-7) to fit all kinds of battery connectors
Specifications :
Applied to almost all balance and lipo battery pack
Balance 2 battery packs simultaneously
Size :---------------70mm x 40mm x 8mm
Weight :----------- 10g
mizi79 is offline
