HK ECO6 5.0A MULTICHARGER LIPO NIMH NICD
1 Attachment(s)
100% brand new Capable of charging any size Lipoly battery up to 6 cells or at 5A. The ECO-SIX includes an array of charging plugs and wires to suit almost any application and comes with JST-XH balancing plugs so you can charge and balance your ZIPPY/TURNIGY packs easily. Input power is 11-18v, perfect for car batteries or pc/laptop powersupply. Features; Microprocessor controlled Delta-peak sensitivity (NiMH/NiCd) Individual cell balancing Li-ion, LiPo and LiFe capable Ni-Cd and NiMH capable Large range of charge currents Store function, allows safe storage current Time limit function Input voltage monitoring. (Protects car batteries at the field) Data storage (Store up to 5 packs in memory) Battery break in and cycling. Spec. Input Voltage: 11~18v Circuit power: Max Charge: 50W / Max Discharge: 5W Charge Current Range: .1~5.0A Ni-MH/NiCd cells: 1~15 Li-ion/Poly cells: 1~6 Pb battery voltage: 2~20v Weight: 170g Dimensions: 138x75x23mm RM110/set call or sms 012-6622527 alan |
