MUCH MORE Cell Master Charger MM-CTXC
Old 03-29-2010, 01:44 AM
bigwig's Avatar
Trader Rating: 33 (100%+)
Default MUCH MORE Cell Master Charger MM-CTXC
SOLD. Thank you.
USED MUCH MORE Cell Master Charger/Disharger for Ni-CD/Ni-MH/Li-Po (MM-CTXC)
In good condition and never fault-peak. Comes with box & manual. Sell at "as-is basis".
FEATURES:
16bit high-resolution charge accuracy.
Muchmore's own false-peak detection algorithm.
4kinds of charge cutoff system and display: Zero delta peak cut, peak cut, capacity cut, temperature cut.
6 user adjustable charge modes: Peak charge x 3, CTX charge x 3
Each 6 charge modes are customizable, quickly recall desired profile.
*Provides last data (charge, discharge, cycle)
*Charge: total charge time, peak voltage, capacity(mAh), temperature at charge cutoff, elapsed time after charge cutoff.
*Discharge: total discharge time, internal resistance, temperature at discharge cutoff, time after discharge cutoff.
*Cycle: each cycling's charge, discharge data.
White back lit display, Blue LED state indicator.
Microprocessor controlled delayed charge timer
Trickle charge after charge termination (can also be disabled)
AAuto start charge up to 18 hours.
Peak Charge: Super linear charge
CTX Charge: 1/3-2/3-3/3 step charge
Li-Ion & Polimer Charge: up to 3 cell
Discharge: 0.1~1A 0.1~9.9V cutoff
Cycle: Up to 3 times repetition
Last Data: Save CHG, DCH, CYC data
Protections: Input/Output reverse voltage and Short circuits Shorted batteries, Thermal overland
Auto restart system when power fails.
SPECIFICATIONS:
Dimensions: 124x114x47mm
Weight: 482g
No. of cells: 1~8
Max charge current: 0.1~10.0A (adjustable)
Discharge current: 0.1~10.0A (adjustable)
Cut-off Voltage: 0.1~9.9V (adjustable)
Input Voltage: 10.0~16.0V
Charging Capability: 10~9990mAh (adjustable)
Charging Modes: Peak & CTX charge, Trickle, Flex, Litheum
Trickle Charge Rate (After Charge): 0.1A
Voltage Threshold/Delta Peak: Zero, 3~99mV
Flex Charge: 0~9 Level (adjustable)
Thermometer sensor: 15~70degrees Celcious
Keys: 4
Cooling: Ball bearing temp controlled dual fans
Selling RM220.00. Price might be higher compare to those China chargers but if you want to have a real peak charge and protect your batteries, this charger can definitely do it.
Reason : Upgrade to Bantam e-Station charger
Item in Kuching or can post within Malaysia (buyer pay).
Please PM or Call/SMS @ 016-6559990.
Thanks.
Attached Thumbnails MUCH MORE Cell Master Charger MM-CTXC-01.jpg   MUCH MORE Cell Master Charger MM-CTXC-dscf0472.jpg
bigwig is offline
