Roche Ceramic Bearing 5x10x4 (Red Rubber Seal) >
Old 03-15-2010, 07:21 PM
kschu's Avatar
Trader Rating: 16 (100%+)
Default Roche Ceramic Bearing 5x10x4 (Red Rubber Seal)
Item : Roche Ceramic Bearing (2pcs)
Size : 5x10x4 - suitable to Tamiya, Yokomo, Xray, Top
Price : Rm28/pack
Qty : 5 Packs
Description :
Ceramic ball are made from pure Silicon Nitride(SI3N4) material with extreme high density from uniform compaction .
They are 60% lighter in weight, and 7 times harder than steel. Friction is reduced to near zero. So your car acceleration will be better and Top speed will be even better.
THE Rubber SEALS are "LLB" low contact labyrinth type, with both side. After few run, you will notice your bearing will get even smoother when the bearing do a matching groove on the inner seal . Please do simple cleaning on the bearing after 10-20 pack of run by opening the rubber seal and spray with Motor Cleaner.After that re-oil with Bearing oil (teflon oil will be the best) or Engine oil( fully synthetic) . This will ensure the bearing last longer and smoother...
Grab a pack and try it yourself...
Postage is rm4 to everywhere of Malaysia by using Pos Express.
PM or sms me at 0168362899
Attached Thumbnails Roche Ceramic Bearing 5x10x4 (Red Rubber Seal)-bearing.jpg
kschu is offline
Old 03-15-2010, 10:35 PM
janzbp's Avatar
bro, this bearing suitble for xray t2009 front solid axle & rear diff??
if "ngam" i want 2 pack....pm me ya......0177029123
janzbp is offline
Old 03-15-2010, 11:23 PM
kschu's Avatar
Hi, this is can fit for knuckle and rear hub and center layshaft of t2009/t3.
The spoo/diff bearing size is 10x15x4, which is coming....
kschu is offline
Old 03-17-2010, 04:07 AM
kschu's Avatar
bump bump
kschu is offline
Old 03-19-2010, 11:55 PM
kschu's Avatar
1st batch sold...
new batch will come next week.
thanks
kschu is offline
