TAMIYA F201 RC CAR
Old 02-16-2010, 09:18 PM
noblercplayer's Avatar
Thumbs up TAMIYA F201 RC CAR
WITH MANY MANY SPARE PARTS & HOP-UP PARTS. 2 EXTRA CHASIS
2 DIFFRENT TAMIYA F201 BODY SHELLS
you take out the shaft it becomes rear wheel drive
CLEARING MY HOBBY
USED FOR ABOUT 10 TIMES IN LAST 3 MONTHS
ALL TO GO RM 1800.00 , i spent more than Rm 3000 on all the hop-ups
CALL 012-6935923 , COD puchong or POSLAJU ALSO can
below are the parts i will give with the car : NEW IN PACKET
Tamiya #50932 x 1 D parts ( Rm 55), Tamiya # 50933 E PARTS (65)
TAMIYA #50939 F201 DRIVE SHAFT (RM70) TAMIYA # 50941 BALL DIFF PLATE (RM 25) , TAMIYA BALL DIFF JOINT CUP X 2 PACKET (RM 120)
TAMIYA #50931 F201 GEAR CASE x 1(RM 85), TAMIYA # 50938 REAR TIRE (RM60) , TAMIYA # 50930 CHASIS X 1 ( RM 250), TAMIYA #9465592 C PARTS OF GEARS ,
SUSPENSION PIVOT NUT,
TAMIYA # 50934 X 6 PACKET ( RM 300), TAMIYA # 50935 X 1 (RM 60)
HOP-UPS : TAMIYA # 53515 F201 RACING SPRING SET X 1 (RM 85)
TAMIYA #53554 LIGHTWEIGHT COUNTER GEARS (RM 65)
TAMIYA # 53553 LIGHTWEIGHT PROPPELER JOINT SET (RM 85)
TAMIYA # 53552 HIGH SPEED GEAR SET (RM 60)
TAMIYA # 53524 F201 ALUMINUM MOTOR GUARD (RM70)
LOOSE PARTS BUT NEW : CARBON REINFORCE PLATE X 1
DRIVE SHAFT LONG X2 , RING GEAR X3 , BEVEL GEAR X 4, SPUR GEAR X 2
METAL DRIVE AXLE X 2 , UNIVERSAL SHAFT X3, SHOCK DAMPER SHAFT X 4 ,
ALL METAL GEARS X 1 SET , PIVOT NUTS X 8, BODY SHELL X2 , CHASIS X1
SUSPENSION ARMS X 2 , FRONT & BACK , ARM KNUCKLES X 1 SET
ALL RM 1800.00 ONLY , CALL ME ON 012-6935923
noblercplayer is offline
