WTS-TT01d rolling chassis+BlueHopUps+MX-A+Discharger+Charger+SP-driftmaster combo!! >
Old 11-08-2009, 09:22 PM
Default WTS-TT01d rolling chassis+BlueHopUps+MX-A+Discharger+Charger+SP-driftmaster combo!!
Item Description: TT01 rolling chassis + alot hopup parts + EVERYTHING I HAVE (see list below)
Used or New : used 2mth
Condition : 9/10
New Price : RM 1200
Reason for sell : NO MORE TIME TO PLAY DUE TO WORK
Terms : COD - Call or SMS 012-3293098 Terence
Hopup Parts :
1- Tamiya (#53792) Assembly Universal Shaft (TT01, TA04) - new
2- Tamiya (#54026) - Tamiya Aluminium Propeller Joint & and Shaft Set for TT-01 - new
3- Tamiya (#53662) - Tamiya Turnbuckle Tie-Rod Set TT-01 - new
4- Tamiya (#53695) - Tamiya TT-01 Rear Stabilizer Set
5- Tamiya (#53694) - Tamiya TT-01 Front Stabilizer Set
6- Tamiya (#53672) - Tamiya Carbon Upper Frame TT-01
7- Tamiya (#53497) - Tamiya Ball Bearing Set for TT01 / TT-01 Chassis
8- Tamiya (#53790) - Tamiya Cup Joint For Universal Shaft (TT-01 and DF-02) - new
9- Tamiya (#51001) - Tamiya Bathtub Chassis TT-01 / TT01 – new
10-Tamiya (#53670)- Tamiya TT-01 Aluminium Steering Set
11-3racing Tamiya TT-01 Chassis Aluminium Rear Hub Carrier
12-3racing Tamiya TT-01 Chassis Aluminium Upper Suspension Mount
13-3racing Tamiya TT-01 Chassis Knuckle Arm
14-3racing Tamiya TT-01 Chassis Diff. Outer Join
15-Jazrider Tamiya TT-01 Alloy Wheel Hex Drive Adaptor (Blue) - new
16-Jazrider Tamiya TT-01 Alloy Steering Tie Rod Set (Blue) - new
17-HobbySave (#HSP008B) - Alloy Rear Lower Arm ( Blue ) for TT-01
18-HobbySave (#HSP045B) - Alloy Front Lower Arm Set ( Blue ) for TT-01
19-HobbySave (#HSP118B) - Alloy Oil Shock Damper for Tamiya TT-01/TT01 TL-01 TA04 TA05 TRF M-Chassis - new
The bathtub is new so all the screws are tight. Very light scratches on the bottom as mostly play at Tamiya Underground Carpet Track.
All other stuff :
1. 2 body shell : Red GTR condition 8/10, Black Supra condition 5/10 (comes with light control)
2. SANWA MX-A remote control with 27.045AM crystal
3. Speed Passion : DriftMaster Brushless ESC Combo Set (Used 2 times only at Tamiya Underground)
1 x D-manager ESC, 1 x Drift Master Turbo motor, 1 x SMART ESC program unit
4. TEAM WAVE – Lightning 2 Advance Discharge System
5. GT Power V5 – Balanced Charger
6. PowerSupply with Cooling Fan
7. 3 x 4600 battery set & 1 x 3000 battery set
8. 1 set of touring tire with foam inserted on original rims
9. Damper spring set + Tamiya Silicone Damper Oil set (medium)
10. All my tools & extra items & spares such as
i. Allan Key screwdriver
ii. Sanwa Servo
iii. aluminium tie rod
iv. Spurs and Pinion
v. Black and Red Tamiya Spray Can (40% used)
vi. Tamiya Anti Wear grease
vii. Basic Charger
viii. and others (see pic)
Everything for RM1200
CALL or SMS 012-3293098 (Terence)
liquidular is offline
Old 11-09-2009, 11:38 PM
LATEST PRICE UPDATED!! SO LOW YOU CAN'T BELIEVE YOUR EYES!!
