MUGEN MBX6R TRUGGY
Old 03-05-2014, 10:34 AM
Default MUGEN MBX6R TRUGGY
M2C RACING is pleased to announce the release of the MBX6R TRUGGY CHASSIS.
These chassis are made using 1/8 inch(3.25mm) thick 7075 aircraft grade materials and clear anodized.
we have tested and tweeked these chassis to provide the racers a top notch chassis that will perform very well on all surfaces.
this model is made for the tracks with a high wear charastics such as we have in western states , up north and canada as well as softer track surfaces.
this model will give you a much longer chassis life than other models as you can replace the steel skid plates and be back to a new
chassis thickness.
It is important to note that these skid plates fit flush to the bottom of the chassis and will not effect the droop settings and cause you to
scrub speed on the landings.
To read more please click on link
http://www.m2cracing.com/searchquick...?keywords=5350
m2cracing is offline
Old 04-18-2014, 12:06 PM
Default M2C DELRING PILLAR BALL RETAINER BUSHINGS
These bushings are made using delrin, which is a much harder plastic
than the stock models that come with the kits. these bushings are machined and produce a very smooth surface which will allow you to fine
tune the amount of play between the pillar ball and the bushing.
It seems that over time, the stock bushings will wear a flat spot at the top
of the bushing. If not changed the bushing will develop some play.
And when we remove or adjust them to remove the play the worn spot may rotate.
then for some reason the pillar ball will unscrew the stud.
We have tested them for several months now and feel confident that
this will take less maintenance.
To order this part please click on link below.
http://m2cracing.com/searchquick-sub...?keywords=5218
