Go Back  R/C Tech Forums > North American Regional Forums > Louisiana Racing Fourm
34MM STEEL ADJUSTABLE  WEIGHT QUICK CHANGE FLYWHEEL SYSTEM FROM M2C RACING >
Old 02-06-2012, 08:42 PM
Default 34MM STEEL ADJUSTABLE WEIGHT QUICK CHANGE FLYWHEEL SYSTEM FROM M2C RACING
M2C RACING is pleased to announce the release of our new steel adjustable
quick change flywheel system. part no. 6085
This kit has the same features as our aluminum model .
With the more powerful engines we have now and the lighter vehicles we are
now posed with the problem of having too much power on the bottom end and
it makes it harder to control the spool up of the engine.
t
This new flywheel starts out at 31.5 grams with shoes and is adjustable up to 36.5 grams with the use of the 4mm adjusting screws allowing you to tone down the bottom coming out of corners for the first 3 to 4 feet reducing wheel spin, allowing the vehicle to begin moving foward before loosing traction.
We have tested this product for 2 months and accross the board the test drivers have reported that it has a much more controlable power band.
This flywheel is a definate plus for the sportsman drivers also in that it
is much easier to control the vehicles.
We have also been told that there is a increase in fuel milage and decrease
in tire wear in most cases.
part no. 6085
www.m2cracing.com
m2cracing is offline
Old 02-13-2012, 02:01 PM
easy e's Avatar
Trader Rating: 28 (100%+)
I run this clutch system in my 8 2.0, shoes and springs last 3 times longer than stock.
easy e is offline
