Set-up Sheets
Gimana kalo kita post settingan kita disini.... yah untuk referensi aja :cool: :cool:
Name :
Track and Layout Type : Car : Front Shock Length : Shock Position : Camber Link : Piston : Spring : Oil : Roll Bar : Camber : Castor : Front toe : Ride Height : Width : Rear Shock Length : Shock Position : Camber Link : Piston : Spring : Oil : Roll Bar : Camber : Rear toe : Ride Height : Width : Wheel Base : Tire : Insert : Wheel : Body : Wing : Front Drive : Center Drive : Speed Control : Motor : Brush : Timing : Gear Ratio : Batteries : Traction Additive : Comments : |
Tinggal klik quote aja... nih contohnya :
Originally posted by daniz24 Name : Danny Track and Layout Type : CIS - Surikarn's Style Car : Yokomo MR-4TCSP Front Shock Length : 60.2 mm Shock Position : Std Camber Link : Std Piston : #3 Spring : Yellow Oil : #300 Roll Bar : Silver 1.2 mm Upper Type Camber : -1 Castor : Std 3' Front toe : -1 Ride Height : 5.5 mm Width : Std Rear Shock Length : 60.5 mm Shock Position : Std Camber Link : Std Piston : #3 Spring : Green Oil : #400 Roll Bar : Silver 1.2 mm Camber : -1.5 Rear toe : -1 Ride Height : 6 mm Width : Std Wheel Base : Short Tire : Sorex 32 R Insert : Sorex Type B Medium Wheel : RJ Ride 6 spokes Body : Andy's Stratus Wing : Yokomo 180 mm Front Drive : Oneway Center Drive : Oneway Speed Control : GM V12XC Motor : Reedy Ti 8x2 Brush : Reedy Quasar Timing : 6 mm Gear Ratio : 81/20 Batteries : Sanyo 3000 Traction Additive : Paragon FX2 Comments : Servo mounted Horizontally Some modifications : chassis, upperdeck, belt tensioner and shims to reduce slops |
Ini bener enggak settingnya, jangan jangan jebakan.
Eh gue mau posting tapi belum dapat settingnya jadi nanti dulu deh. |
Originally posted by MissX Ini bener enggak settingnya, jangan jangan jebakan. Eh gue mau posting tapi belum dapat settingnya jadi nanti dulu deh. |
ada kata2 bijak dari mbah hardjo: 'jangan sekali kali percaya apa kata musuhmu.... wakkakakkakkak
Tul...uapa lagi kata-katanya mbah harjo....
oli shock aja pake 10... Camber linknya non adjustable.. Caster depan belakang aktif..bisa rubah sendiri... Belt-nya di tipisin biar enteng... sasisnya pake campuran karet gelang biar flexible.... Sampe speed control aja di modifikasi, biar lepas kabelnya... :ha: :cool: :ha: :ha: |
Originally posted by Team-INEK ada kata2 bijak dari mbah hardjo: 'jangan sekali kali percaya apa kata musuhmu.... wakkakakkakkak |
c'mon guys, he was telling you the truth. you don't want to see Daniz24 Hawaii change to Daniz24 Skiny, do you?
bisa kurus lho dia. set upnya kan beneran ya Daniz24 ;) ;) ;) cuman buat ditrack mana ya....?? |
Originally posted by BerthMaster c'mon guys, he was telling you the truth. you don't want to see Daniz24 Hawaii change to Daniz24 Skiny, do you? bisa kurus lho dia. set upnya kan beneran ya Daniz24 ;) ;) ;) cuman buat ditrack mana ya....?? Itu trek CIS dengan layout Surikarn's style :D |
R U sure?
I think that's the setup for doggy style....Ups..:rolleyes: |
Mobilnya Mbah hardjo sebenernya paling canggih lho!:sneaky: Dia enggak pernah setting tuh mobil....:weird: Wong kalo balap yang nyetir didalam mobil JIN kok..:eek: :eek: :eek:
Track and Layout Type : 1st Series in Bandung (Feb 3rd) Car : Yokomo MR-TCSP Front Shock Length : 60.3 mm Shock Position : Standard Camber Link : Standard Piston : #3 Spring : Green Oil : #400 Roll Bar : 1.2 mm Upper type Camber : -1.5 Castor : Standard Front toe : 0 Ride Height : 6 mm Width : Standard Rear Shock Length : 60.3 mm Shock Position : Standard Camber Link : Standard Piston : #3 Spring : Green Oil : #400 Roll Bar : 1.2 mm Camber : -2 Rear toe : -1 Ride Height : 6.5 mm Width : Standard Wheel Base : Short Tire : Sorex 32R Insert : Yokomo 039F Wheel : RJ Ride 6 Spokes Body : Yokomo Stratus Type B Wing : Standard Front Drive : Oneway Center Drive : Oneway Speed Control : GMV12XC Motor : Reedy Ti 8 Double Brush : Reedy Quasar (#729) Timing : 6 mm Gear Ratio : 81/19 Batteries : Sanyo RC3000 Traction Additive : Paragon FXII Comments : Tire Warmer (weather problem) Current Limiter set to Maximum Reduce slops for more consistant driving Switch to Sanyo HV immediately based on last race !!! |
Originally posted by daniz24 Name : Danny Track and Layout Type : 1st Series in Bandung (Feb 3rd) Car : Yokomo MR-TCSP [ Comments : Tire Warmer (weather problem) Current Limiter set to Maximum Reduce slops for more consistant driving Switch to Sanyo HV immediately based on last race !!! |
Originally posted by juki Hi...hi...hi....kasian bener neh temen gue keteteran sama rombongan HV!!!:D :D :D |
| All times are GMT -7. It is currently 08:32 PM. |
