Originally Posted by beebop
(Post 4919406)
itu decalnya backbone rc.. coba klik www.teambackbone.com |
Originally Posted by v8ruary 94
(Post 4919626)
itu kan decalnya Backbone rc yang didesain buat Hayato Matsuzaki kan??
A123
3 Attachment(s)
Bagi yang mengetahui supply
Battery jenis A123 atau Li-Ion Nanophosphate di Jabodetabek Silahkan di post Alamat dan nomor telepon : __________________________________________ Pembahasan juga bisa dilakukan di sini. apa bila bisa pembahasan di mulai dari hal di bawah karena contoh tipe ini salah satu yang mungkin mudah di implementasikan. 6.6V 2300 Li-Ion Nano Phosphate Hypersonic Pack Specs * Type: Lithium Ion * Capacity: 2300 mAh * Voltage: 6.6V * Connector Type: Deans Ultra (WSD1300) * Number of Cells: 2 * Weight: 155g * Configuration: 2S1P * Dimensions (WxLxH): 135mm length x 28mm diameter * Maximum Continuous Discharge : 30C * Maximum Burst Discharge : 60C ________________________________________ Rupa http://www.evworld.com/images/a123_csize.jpg http://sun-rc.com/images/HP-LA2300-L.jpg |
Charger A123
2 Attachment(s)
Sonic Charger, Li-Ion Nano Phosphate
Key Features * Accepts 12V input power * Charge connector (Deans Ultra) * One charge balancing connector (Only on Hypersonic Batteries) * LED indicates state-of-charge * Fast charge capable 15 minutes Overview Designed exclusively for HypersonicTM and Hypersonic TurboTM battery packs, the Sonic Charge system will automatically detect the number of cells in your pack and charge them in as little as 15 minutes. Thanks to the NanoPhosphate technology from A123Systems, there is no need to worry about thermal runaway or fire. As a result, you no longer need to monitor the battery while charging or use a fire proof box. Orange : Sonic Charger, Li-Ion Nano Phosphate Tech Notes Product Specs: Power Supply: 10-15V DC Charge Cells: 1-3 (Hypersonic™ Packs Only) Cell Balancing: Yes Pole Reversal Protection: Yes Charging Power: Max. 108W Charging Current: Max. 10A Charging Voltage: 3.5-10.5V Status Indicators: LED Fuse: 15A Auto Style Spade Fuse, Input & output Dimensions (W x H x D): 126 x 46 x 82 mm |
salam kenal sebelumnya...saya punya masalah dengan 3PK 2.4GHZ yang saya pake di 1/8 buggy, dimana kalau race lebih dari 30 menit receivernya (tipe 603) itu puuaannasss buangget dan akibatnya fail + loss control ...apakah ada yang tau solusinya? btw apakah receiver 4PK (tipe 604) bisa dipakai dengan 3PK yg 2.4Hz? krn saya liat yg pake 4PK tdk masalah dgn panas ini...terima kasih yah sebelumnya ...:nod::nod::nod:
Originally Posted by Mandi_Susu
(Post 5140128)
(Post 5140128)
(Post 5140128)
Originally Posted by rc168
(Post 5140551)
banyak kalo brg r/c rusak pake 'lembiru'...:nod::nod::flaming::flaming:
eh baru wakakakakak. |
Originally Posted by fabolousRC
(Post 5140366)
Voltase-nya dari batere di liat mas. Jangan2x baterenya overvolt sehingga receiver panas. Kayaknya kalo udah begini mau diganti receiver manapun tetep aja overheat. Kalo misalnya dulu pake Lipo, coba sekarang balik lagi ke Nimh. Soalnya ada receiver yang ngga bisa langsung pake Lipo karena ngga ada built-in voltage regulatornya.
BR : janganlah engkau meracuni daku terus ....:lol::lol::lol: |
(Post 5143174)
thx replynya....tapi battery receiver nggak pernah pake Li-Po padahal ...krn pake li-po mmg sdh banyak korbannya...:lol::lol:
Originally Posted by blackred
(Post 5144371)
berani gonta ganti kit tapi koq gak berani ganti radio yg udah pasti enak? hue he he he
