HK Talk Version 1.1
Old 09-06-2003, 12:36 PM
  #13936
Maj. Teeth's Avatar
Originally posted by dtm
I can get a good connection between the base station and the client. I cannot get a log on from IE to the client! I get no response from the computer. Cause I'm running broadband rather than I cable I do not have a fixed IP address so I have to log on each time with password access.Anyway, I am plugging the LAN line direct to the back of the PC right now! Stuff the Orinoco......bought it quite a few months ago and never used it! when I do get round to using I find it does not work!!
You might have to upgrade the software version. Also, if you're running XP, you can set it for wireless detection via the network properties. Make sure you're logged on as Administrator first before changing this or else it will have no effect. It was a pain in the rear when I had to install it and took me a couple hours to figure out but once done it works great!
Dan
Maj. Teeth is offline
Old 09-06-2003, 12:41 PM
  #13937
Maj. Teeth's Avatar
Oh DTM,
One more think. Go to your IE, click on:
Tools/Internet Options/connections/Lan Settings/ put a check mark on the "automatic detect settings"
Then reboot and you should be good for IE..
Dan
Old 09-06-2003, 08:19 PM
  #13938
dtm
dtm's Avatar
Originally posted by Manticore
i pay you HK$500 for your orinoco set !!
I might just take your offer!!!!
dtm is offline
Old 09-06-2003, 08:21 PM
  #13939
dtm
dtm's Avatar
Dan
Thanks I will give that a try....One thing..me being an XP dummy...how do I log on as an Adminstrator!!! I've been stuck in the dark days of 98 with mu old PC!!
dtm is offline
Old 09-06-2003, 09:20 PM
  #13940
Diva's Avatar
Trader Rating: 14 (100%+)
Dremel test.
Don't be destracted by the news paper under neath.
Diva is offline
Old 09-07-2003, 02:00 AM
  #13941
ernestf's Avatar
where can i get more information about this conversion kit?
i saw it from the latest Jap magazine ... ...
ernestf is offline
  #13942
ernestf's Avatar
Originally posted by Diva
Dremel test.
diva, where is your batt from ??
ernestf is offline
Old 09-07-2003, 03:04 AM
  #13943
fai
Regional Moderator
fai's Avatar
Default Re: Re: Re: Batteries
Originally posted by Jimmy Fukuyama
HI Fai,
I was thinking the same thing around Chinese New Year so maybe I get trade for some "Lai See" at the track. LOL.. I'm actually from Hong Kong but moved to the California sometimes ago, then back to Hong Kong and then stayed in Japan growing up. I still have a girlfriend living in Causeway Bay so I go back 2 times per year.
Jimmy
Jimmy, I see... So, hope you can get back here more frequently!!
fai is offline
Old 09-07-2003, 03:10 AM
  #13944
fai
Regional Moderator
fai's Avatar
Dremel test.
Good 'dremel' work! Would the battery too close to the shaft?!
fai is offline
Old 09-07-2003, 03:42 AM
  #13945
fai
Regional Moderator
fai's Avatar
Secretly, he got that from those sauna ad. on that newspaper...
fai is offline
Old 09-07-2003, 08:27 AM
  #13946
PeterCheung's Avatar
I also did some modify tonight......hehe
It is the pipe's stringer...
PeterCheung is offline
Old 09-07-2003, 08:33 AM
  #13947
another view of the pipe
Old 09-07-2003, 09:40 AM
  #13948
Diva's Avatar
ernestf: I got this pack from Mr. Tam (Roy's father who distribute SMC packs in HK)
fai: there is about 1.5-2mm slot between the battery and the shaft. Plus I have cut the slot for the battery tape. I wish I could make it as good as this. 2 gram difference between left and right.
Petercheung: Why don't you put on foam tire for your skateboard?
Damn rainy days.
Diva is offline
Old 09-07-2003, 09:43 AM
  #13949
Diva's Avatar
Petercheung: What have you modified to the pipe?
Diva is offline
Old 09-08-2003, 12:23 AM
  #13950
i show u the pic of before mod. are u will know
