HK Talk Version 1.1
Old 05-04-2003, 05:56 PM
  #13186
davioh's Avatar
no school...but can't go drive outside with dish plates cuz it's raining
davioh is offline
Old 05-04-2003, 07:37 PM
  #13187
It is a time to go for Mini-Z. Same feeling you can get......at the end straight road...... crash car.
dang is offline
Old 05-04-2003, 07:54 PM
  #13188
davioh's Avatar
i had/have a mini z....it was really good...but now it can barely move...
davioh is offline
Old 05-05-2003, 03:05 AM
  #13189
Default 1/12 new car from Kyosho
dang is offline
Old 05-05-2003, 03:07 AM
  #13190
Attached pls find the link
dang is offline
Old 05-05-2003, 09:08 AM
  #13191
Originally posted by dtm
A Pro 3 is somewhat flexible compared to the Losi. They are 2 cars in the extreme....one ultra flex and the other ultra stiff.
Losi is not without its problems!
Besides the front roll bar I would lay down the rear shocks flatter, increase rear camber (not more than 2 deg), rear toe -in, increase rear droop (longer shocks). Do the things one at a time a see the difference.
I have some confusion with the terms
When you are increasing droop, is that the 'reading' of the droop gauge increase? [shorter shock]
or the other way around
Mingfinity is offline
Old 05-05-2003, 10:06 AM
  #13192
KY9fat's Avatar
shouldn't your droop gauge go "-ve" when you shorten your shocks? i.e. DECREASING Droops!
KY9fat is offline
Old 05-05-2003, 10:16 AM
  #13193
dtm
dtm's Avatar
Haha...Lengthen the shocks anyway.....depending which way you look at it. If you increase the shock length the amount your wheels drop when you lift the car (droop) increases...........whatever!
dtm is offline
Old 05-05-2003, 10:18 AM
  #13194
dtm
dtm's Avatar
I hope not! mine goes more +ve when I shorten the shocks!
dtm is offline
Old 05-06-2003, 12:21 AM
  #13195
Found in LOSI's site
http://www.teamlosi.com/techtips/xxxs/front_droop.jpg
Old 05-06-2003, 07:51 AM
  #13196
fai
Regional Moderator
fai's Avatar
Originally posted by andyhui
It's great, man!
fai is offline
Old 05-06-2003, 07:55 AM
  #13197
fai
Regional Moderator
fai's Avatar
Mingfinity: DTM means going to 2/1mm on the gauge then. I did run a Pro3 for nearly half a year some time ago... I stopped once the graphite lower chasis came out...
fai is offline
Old 05-06-2003, 09:59 AM
  #13198
dtm
dtm's Avatar
Haha...the Hudy one goes from -ve to +ve....just to confuse things!!
dtm is offline
Old 05-06-2003, 10:01 AM
  #13199
dtm
dtm's Avatar
Good move...and I bet you never looked back!! hehe......
BTW...how was your Type T when you ran it?...there is a damn cheap Type T in CC S/H! This car has worst re-sale value than an Alfa!!
dtm is offline
Old 05-06-2003, 10:03 AM
  #13200
dtm
dtm's Avatar
I got the SSG upper deck and shock towers for my TA04R tonight.....man this SSG is like Tofu!!! damn flexible...I'm not sure how long I will leave it on the car!!!
dtm is offline
