HK Talk Version 1.1
Old 05-02-2003, 09:53 AM
  #13156
Unhappy
Originally posted by dtm
After a day of GP running on the track...the traction gets quite high.....I have notice a marked increase in the grip at EGR after the GPs have gone home!
[email protected]#[email protected]$
a lot to learn to tune the car then
How to solve the problem that ... my car seems .. oversteer when existing a turn?
Mount the rear camber link higher on the hub?
or... decrease the droop by make the rear shock longer?
Mingfinity is offline
Old 05-02-2003, 09:58 AM
  #13157
davioh's Avatar
can EP catch up to GP's?
davioh is offline
Old 05-02-2003, 01:48 PM
  #13158
Originals that came with the car..purple (20lbs) fronts and silver (12.5lbs) rears. I tried the dark greens(17.5 lbs) on the front didn't like it, the front of the car goes down and does not want to go back up in a turn.
Will try out the blues (14.5lbs) in the rear this weekend because the car still has too much grip in the back. I'm running 1.5 deg toe in for the back. It is like driving a train with 2 deg!
Will also try and go up to 40wt oil (from 30wt) because the chicane response is too slow. Fine for single bends....
Shorten the rear camber links. #2 holes in the shock tower and the inner hole in the rear uprights.
Run the rear arms in the full forward position.
Stand the rear shock up a hole in the shock tower.
Don't run Purple fronts with Silver rears.
Don't run the low roll centers in the rear.
Hmmm broke the chassis? How fast were you going? What did it have in it? An MTO?
Sydewynder is offline
Old 05-02-2003, 07:40 PM
  #13159
dtm
dtm's Avatar
hmmm...great minds think alike...I have tried everything on your list already! (except for the springs....for today! ). I may try a rear roll bar if I can be bother to stop off at MK before the track today..
As for the chassis breaking...9T...end of straight....clipped the corner....6ft launch....side of car into a concrete barrier when it landed.....get the picture!! Actually the chassis broke because the battery flew out and hit the side of the tub...
dtm is offline
Old 05-02-2003, 07:42 PM
  #13160
dtm
dtm's Avatar
First of all....what car are you running??....if it is something I have I can give you more specific details..
dtm is offline
Old 05-02-2003, 07:44 PM
  #13161
dtm
dtm's Avatar
Catch GP??? On the right track (read... small and technical) EP can overtake GP!!
dtm is offline
Old 05-02-2003, 08:24 PM
  #13162
Manticore's Avatar
that track must be smaller then PYC a lot !
Manticore is offline
Old 05-02-2003, 08:53 PM
  #13163
dtm
dtm's Avatar
When PYC sets its most technical track...you GP guys only gain on the straight!!
dtm is offline
Old 05-02-2003, 08:55 PM
  #13164
dtm
dtm's Avatar
rain...rain...rain....ah well it looks like staying indoors today!!!
dtm is offline
Old 05-02-2003, 09:38 PM
  #13165
fai
Regional Moderator
fai's Avatar
One more thing...the insets have a lot to do with the traction too. Yok 039F are good but you will be lucky if you can re-use them once. I am using Sorex Type C Med or Firm...these appear to give me much better wear patterns and grip...also they are almost like new after wearing out one set of tires!
I sometimes ran HPI orange inserts and they also give better tire-wear to 039F!
DTM: I've bought Sorex Type C medium already, can't wait to test them!
fai is offline
Old 05-02-2003, 09:41 PM
  #13166
fai
Regional Moderator
fai's Avatar
Mingfinity: How about installing a front roll bar first?
fai is offline
Old 05-02-2003, 09:45 PM
  #13167
fai
Regional Moderator
fai's Avatar
Originally posted by ernestf
thanks. the toothache is gone without any operation.
will visit the track with my type T tomorrow. Xray still in "3-leg" mode ....
Ernest: My tooth care tips are to brush every morning/night for 5 minutes and stay away for sweet food! Touch wood, I've been to dentist for nearly 15years lar! Oops... out of RC topics!
fai is offline
Old 05-02-2003, 09:49 PM
  #13168
fai
Regional Moderator
fai's Avatar
Yeah Yeah... no mood to go out of office...
Have you picked up your Losi spur-gear adapter yet? I saw it last night at MK, will the word 'state-of-art' be exaggerating??
fai is offline
Old 05-02-2003, 10:03 PM
  #13169
ernestf's Avatar
fai, i did that since i am a child. not only 2 times, at least 3 times a day (after lunch in office) .....
rainning today in SG too, no way to run my RC ....
ernestf is offline
Old 05-02-2003, 10:05 PM
  #13170
Manticore's Avatar
you forget how I overtook you on the corners?
