HK Talk Version 1.1
Old 05-01-2003, 08:47 AM
  #13141
dtm
dtm's Avatar
Originally posted by KY9fat
Dentist tomorrow
I'm driving in tomorrow, I kept the Battin my car. If Mr. Dick going to MK I'll give it to Him.
I need to go in for a mtg tomorrow...leave them on my desk! Thks...
dtm is offline
Old 05-01-2003, 07:34 PM
  #13142
Manticore's Avatar
Dentist tomorrow
Dentist !!!!!!!!!!!!!!!!!!!
We keep ourself away from Med Doc these days for minor health problem including toothache !
Manticore is offline
Old 05-01-2003, 10:44 PM
  #13143
PeterCheung's Avatar
PeterCheung is offline
Old 05-01-2003, 10:46 PM
  #13144
Old 05-02-2003, 06:03 AM
  #13145
ernestf's Avatar
wah wah. Kyosho will make GP to another standard !! i see nothing on the new RR (not sure its name) upper deck .......
ernestf is offline
Old 05-02-2003, 08:23 AM
  #13146
fai
Regional Moderator
fai's Avatar
Ernest: Had you toothache gone?!
fai is offline
Old 05-02-2003, 09:49 AM
  #13147
ernestf's Avatar
thanks. the toothache is gone without any operation.
will visit the track with my type T tomorrow. Xray still in "3-leg" mode ....
ernestf is offline
Old 05-02-2003, 10:04 AM
  #13148
Default Need help from expert
I always have problem selecting my tires.
When i heard ppl are using 36R, i always need to use 32R
when i heard ppl they are running 32R, I always need to use 28R to have good result.
Usually how long does the tire last? at least 10 runs? Or my tires are fully worn... so i need to use a softer one.
Mingfinity is offline
Old 05-02-2003, 10:17 AM
  #13149
dtm
dtm's Avatar
36R all the way.......during the day I may even use 40R. PYC has more grip than EGR but it should be pretty much the same. Use FXII traction compound if you are struggling for grip. A set of 36R should last a good 30+ packs.....I like to rotate the tires L to R but not front to back. You will find the fronts wear quicker....in this case keep the rears....open a new set...run these down. Now you will end up with 2 sets of half worn rears....these will be good for another 10-20 packs!!
dtm is offline
Old 05-02-2003, 10:18 AM
  #13150
dtm
dtm's Avatar
In fact use traction compound at all times.....36R seems to run funny without it!
dtm is offline
Old 05-02-2003, 10:21 AM
  #13151
dtm
dtm's Avatar
One more thing...the insets have a lot to do with the traction too. Yok 039F are good but you will be lucky if you can re-use them once. I am using Sorex Type C Med or Firm...these appear to give me much better wear patterns and grip...also they are almost like new after wearing out one set of tires!
dtm is offline
Old 05-02-2003, 10:28 AM
  #13152
I usually go to EGR after 7pm.. i think at that time the track is kind of cooled already? I will re-try my 36R and new set of 32R tmr...
and try to learn how to tune my car
.. still a newbie
Old 05-02-2003, 10:30 AM
  #13153
Only change the tire.. when u see down to the Nylon belt?
Old 05-02-2003, 10:41 AM
  #13154
dtm
dtm's Avatar
Yes...for normal running this is fine...you don't want to throw money away!
dtm is offline
Old 05-02-2003, 10:43 AM
  #13155
dtm
dtm's Avatar
.. still a newbie
After a day of GP running on the track...the traction gets quite high.....I have notice a marked increase in the grip at EGR after the GPs have gone home!
dtm is offline
