HK Talk Version 1.1
Old 03-21-2003, 06:16 AM
  #12856
LeoChan's Avatar
Default DTM :
Tomorrow what time go to PYC ?
LeoChan is offline
Old 03-21-2003, 07:33 AM
  #12857
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Steering Problem
Originally posted by Manticore
futaba, sanwa and ko make good servos but I prefer futaba servos because of the reliability. for one of its top of the line servo, it will cost you from 500 to 700 HK$
How much is Futaba 9450 and 9451?
Thanks.
Raymond is offline
Old 03-21-2003, 07:37 AM
  #12858
dtm
dtm's Avatar
Default Re: DTM :
I'll leave around 3:00pm ish...
dtm is offline
Old 03-21-2003, 07:39 AM
  #12859
dtm
dtm's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Steering Problem
Thanks.
KO will be release a series of servos soooonn.......
The 945x should be around the 500 mark.
dtm is offline
Old 03-21-2003, 07:42 AM
  #12860
Default Re: Re: Steering Problem
Originally posted by dtm
Is this will the car off the ground and only at full steering lock? If this is the case then it is normal, the CVD cross pin has gone to the end of its slot and is locking....... don't worry about it. The Xray ball ends are the best there are....a little bit of play is normal.
Off the ground is OK. When I put on the ground and at max steering throw, the inner wheel wobbles. I found that the play in the ball joints is one of the problems.
Another thing is to use the inner holes of the servo saver might help.
PS: I am using the front one-way.
Thanks.
Raymond is offline
Old 03-21-2003, 07:44 AM
  #12861
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Steering Problem
9450 or 9451 better? are they just normal servo connected to the receiver (no addtional circuit required?)
KO better??
Raymond is offline
Old 03-21-2003, 07:52 AM
  #12862
Manticore's Avatar
the KO servo working noise is too scary !
Manticore is offline
Old 03-21-2003, 08:10 AM
  #12863
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Steering Problem
OK, thanks.
What is the difference between 9450 and 9451?? Can the JR receiver just connect to it without any problem??
Raymond is offline
Old 03-21-2003, 08:15 AM
  #12864
Manticore's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Steering Problem
OK, thanks.
9451 replaces 9450 but from the spec 9451 is better?
all servos are interchangable but you need to observe the wire position.
Old 03-21-2003, 08:32 AM
  #12865
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Steering Problem
9450 better??
Raymond is offline
Old 03-21-2003, 08:48 AM
  #12866
Manticore's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Steering Problem
9450 better??
i use both 9450 and 9451 and I cannot tell the difference.
Old 03-21-2003, 09:29 AM
  #12867
dtm
dtm's Avatar
KO better??
My preference is KO...Manti is Futaba....both are good!
dtm is offline
Old 03-21-2003, 09:33 AM
  #12868
PeterCheung's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Steering Problem
as i think, the performance of the servos which around $500 are similar, becoz i can't feel the difference...... haha
PeterCheung is offline
Old 03-21-2003, 09:35 AM
  #12869
Manti,
u still have a sanwa VR servo and servo horn at my home....
do u still remember??
Old 03-21-2003, 04:05 PM
  #12870
TFR
TFR's Avatar
a new series of Ko Propo servos?? any more info about this??
TFR is offline
