HK Talk Version 1.1
Old 03-20-2003, 02:45 PM
  #12841
PizzaDude's Avatar
Andyhui,
Man looks really awesome!
You can paint my body anytime...
CU
Pizza
PizzaDude is offline
Old 03-20-2003, 08:35 PM
  #12842
Originally posted by andyhui
last week i painted new body shell for my brother TB3
Excellent painting work!!
BTW, how to paint the headlights and the radiator masks??
Raymond is offline
Old 03-20-2003, 10:51 PM
  #12843
fai
Regional Moderator
fai's Avatar
Originally posted by Raymond
Expert fai, you don't know this really??
carpet: sorex 28 ( for low temp), yokomo 37F or 39F
or Yokomo GS (for low temp)
Thanks! Oh, I'm not expert coz I just equip all my four dampers with springs of same spring rate!!!
fai is offline
Old 03-20-2003, 10:52 PM
  #12844
fai
Regional Moderator
fai's Avatar
DTM: Any RC this week?? Do you need to prepare for your Tamiya?
fai is offline
Old 03-20-2003, 11:09 PM
  #12845
Default Steering Problem
I got an XRAY T1 EVO2. When my car turns, the inside wheel wobbles/vibrates seriously. I cannot figure out whether it is the pivot ball linkage problem or the axle problem.
Anybody can help? Thanks.
Raymond is offline
Old 03-21-2003, 12:02 AM
  #12846
Manticore's Avatar
Default Re: Steering Problem
tighten up your servo saver
Manticore is offline
Old 03-21-2003, 12:21 AM
  #12847
Default Re: Re: Steering Problem
The servo saver is connected to linkages using pivot balls. The only thing I can tighten up is the screw on the servo horn. Do you mean that screw??
I found that there is little play on every ball cup. Do I need to change the linkages and the ball cups??
This is very frustating.
Thanks.
Raymond is offline
Old 03-21-2003, 12:27 AM
  #12848
Manticore's Avatar
Default Re: Re: Re: Steering Problem
Thanks.
whaat kind of servo you use for steering?
Old 03-21-2003, 12:29 AM
  #12849
Default Re: Re: Re: Re: Steering Problem
Cheap cheap servo that comes with JR Racing XR2 radio.
Raymond is offline
Old 03-21-2003, 02:12 AM
  #12850
Manticore's Avatar
Default Re: Re: Re: Re: Re: Steering Problem
Old 03-21-2003, 02:13 AM
  #12851
Manticore's Avatar
Default Re: Re: Re: Re: Re: Re: Steering Problem
your steering servo must have strong holding power to keep your wheels in desire steering direction on corners.
Old 03-21-2003, 02:38 AM
  #12852
Default Re: Re: Re: Re: Re: Re: Re: Steering Problem
Thanks, I agree with you.
Perhaps, I played with the linkages too much (uninstall and snap them back many times). I will replace the linkages first and see whether it improves.
I'll get a better servo later. Is Futaba servo OK, and what is the price?
Raymond is offline
Old 03-21-2003, 03:49 AM
  #12853
Manticore's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Steering Problem
futaba, sanwa and ko make good servos but I prefer futaba servos because of the reliability. for one of its top of the line servo, it will cost you from 500 to 700 HK$
Old 03-21-2003, 06:03 AM
  #12854
LeoChan's Avatar
Default FAI :
Can't go to race ?
LeoChan is offline
Old 03-21-2003, 06:11 AM
  #12855
dtm
dtm's Avatar
Is this will the car off the ground and only at full steering lock? If this is the case then it is normal, the CVD cross pin has gone to the end of its slot and is locking....... don't worry about it. The Xray ball ends are the best there are....a little bit of play is normal.
dtm is offline
