HK Talk Version 1.1
Old 02-26-2003, 11:24 PM
  #12556
Diva's Avatar
Trader Rating: 14 (100%+)
Default Re: Re: Comm lathe
Originally posted by fai
I heard they will charge you ~$30 for each lathe cut. I don't think they will replace brushes for you... You can change by yourself anytime.
As a long term, it's really worth to get one. My Hudy lathe had been with me for nearly 2 years lar... But, as a start in RC, it's really better to buy/do lathe/cuttting by later!
Raymond: I think you'd better ask for one stop shop service since after lathe cut, you still have to tune the timing and run-in the brush. That's what I did before I got my lathe.
Diva is offline
Old 02-26-2003, 11:25 PM
  #12557
Diva's Avatar
New avatar! Want to have a closer look!?
New target
Diva is offline
Old 02-27-2003, 01:30 AM
  #12558
Default Re: Re: Re: Comm lathe
Timing needs to be changed after true the comm?
Mingfinity is offline
Old 02-27-2003, 04:28 AM
  #12559
Thanks, Speedome did the cut for me. I probably will buy one after I upgraded my radio and servo. It will take some time.
Raymond is offline
Old 02-27-2003, 04:31 AM
  #12560
Default Re: Re: Re: Re: Comm lathe
I don't know whether Speedome had tuned the timing for me or not. I will check with them again. I think the orginal hood position had not been changed.
Raymond is offline
Old 02-27-2003, 04:39 AM
  #12561
Default Re: Re: Not enough punch
Raymond, I don't know the internal gear ratio of TBII but your final gear ratio with 23T should be ~4.9->5.3 just like DTM mentioned before! So, in your case, you may use smaller pinion in order to gain some torque... On the other hand, you can also use a spur gear as large as possible! (Oh, don't be too large and come out of the chasis!) Hope this helps!
Thanks,
drive ratio of EVO2 is 2.125. I am using spur/115, pinion/43. The total ration should be 5.68. Should be within range.
I got another spur/116 and pinion/47. Also within range. I may try larger spur gear later.
Raymond is offline
  #12562
dtm
dtm's Avatar
No, not really, but you do have to run in your brushes again before you get the perfermance back.
dtm is offline
Old 02-27-2003, 04:43 AM
  #12563
Default Re: Re: Re: Re: Re: Comm lathe
OK, Thanks.
Raymond is offline
Old 02-27-2003, 06:02 PM
  #12564
Default WARPSPEED RACING
To be released on Friday, February 28th,
THE WARPSPEED DEMON
If you would like any information, email me at
[email protected]
Mr Warpspeed is offline
Old 02-27-2003, 06:04 PM
  #12565
Here is another pic of the DEMON!!!!
Old 02-27-2003, 06:43 PM
  #12566
Diva's Avatar
Not always a must. But since the comm will become trimmer after cut and new brushes are replaced, the rev and current drawn will change. I would usually measure the current drawn and revolution to get the optimum condition. Timing might need to be adjusted. So a motor checker is always working with the comm lathe.
Just my 2 cents
Diva is offline
Old 02-27-2003, 11:18 PM
  #12567
fai
Regional Moderator
fai's Avatar
Raymond: Stock motor cannot change timing! Your Xenon is a stock!
fai is offline
Old 02-27-2003, 11:20 PM
  #12568
fai
Regional Moderator
fai's Avatar
DTM: Reaally willing to join you guys tomorrow but have something to do at evening time! So I plan to try Ernest's schedule: 9:00->15:00 (Ernest's: 7:00->12:00) at PYC! Anybody there?!
fai is offline
Old 02-27-2003, 11:24 PM
  #12569
Wa!! 7:00am, early bird special.
Raymond is offline
Old 02-27-2003, 11:30 PM
  #12570
Diva's Avatar
Congratulation. At that time, you'd save your car -- too early for me to aim at the new target.
Diva is offline
