HK Talk Version 1.1
Old 02-26-2003, 03:05 AM
  #12541
dtm
dtm's Avatar
Default Re: Hobby Shops
Originally posted by Raymond
I don't want to bad-mouth any shop. As long as the money still in you pocket, just spend it wisely.
We have no problems with bad mouthing shops! If they are grumpy gits and don't say hello when I go into the shop......I don't spend money! Way overpriced/or flexible pricing...I don't spend money...
It's MY money and its their loss if they don't treat their customers nicely.....haven't they seen the adverts on TV??
dtm is offline
Old 02-26-2003, 07:05 AM
  #12542
KY9fat's Avatar
Default Re: Re: Re: Re: Re: The RC hobby
Originally posted by Mingfinity
By the way,
where still have Mini Xpress parts?
Well, Nikis used to have them before they moved. Now I don't even know where their shop is.
The shop opposite (diagonally) Control Center still have some Xpress parts. Or you can always try GPM
KY9fat is offline
Old 02-26-2003, 07:08 AM
  #12543
KY9fat's Avatar
Default Xpress site
or this
http://www.rc-xpress.com/
KY9fat is offline
Old 02-26-2003, 07:35 AM
  #12544
Default Re: Re: Re: Re: Re: Re: The RC hobby
I think Nikis seems moved to 12/F ?
Mingfinity is offline
Old 02-26-2003, 07:42 AM
  #12545
No kidding
i think the last method is to try GPM
: P
as I only want to make the MINI Xpress to run and have fun, not to race
Old 02-26-2003, 06:51 PM
  #12546
Diva's Avatar
Trader Rating: 14 (100%+)
Default Re: Re: Re: Re: Re: Re: Re: The RC hobby
No kidding
: P
Don't forget to install the lights
Diva is offline
Old 02-26-2003, 07:20 PM
  #12547
Default Re: Re: Re: Re: Re: Re: Re: Re: The RC hobby
Currently i am restoring my MiniXpress
Should i use the MINI wheel or the TC wheel just like the new Yokomo MiniTC?
Old 02-26-2003, 07:32 PM
  #12548
Default Diode across the motor
Hi guys,
What is the advantage to install a diode across the motor? If it is installed, does it mean that I cannot do reverse?
Raymond is offline
Old 02-26-2003, 07:34 PM
  #12549
Default Comm lathe
How much is it to lathe the Comm and replace the brushes in KW street shops??
Is it justified to buy my own Comm lathe??
Raymond is offline
Old 02-26-2003, 07:45 PM
  #12550
Default Not enough punch
I am running the standard EVO2,
I am using the following equipment:
- 23T Xenon motor
- GP3000 and GP3300
- futaba 330 ESC (quite hot after run)
- pinion 64p/43T, spur 64p/115T
I just have the comm lathe and the brushes replaced. However I found that the punch is weak during acceleration. Could any body give some advise on that? Thanks.
I am also thinking of getting the front one-way differential.
Raymond is offline
Old 02-26-2003, 09:56 PM
  #12551
fai
Regional Moderator
fai's Avatar
New avatar! Want to have a closer look!?
fai is offline
Old 02-26-2003, 10:01 PM
  #12552
fai
Regional Moderator
fai's Avatar
Default Re: Diode across the motor
Hi guys,
Yes! Reverse ESC, no diode! Honestly, I really don't clearly understand the behind theory of installing diode, but from my Yokomo MMS motor checker, install two diodes in parallel reduce amp draw but no revolutions down!!
fai is offline
Old 02-26-2003, 10:04 PM
  #12553
fai
Regional Moderator
fai's Avatar
Default Re: Comm lathe
I heard they will charge you ~$30 for each lathe cut. I don't think they will replace brushes for you... You can change by yourself anytime.
As a long term, it's really worth to get one. My Hudy lathe had been with me for nearly 2 years lar... But, as a start in RC, it's really better to buy/do lathe/cuttting by later!
fai is offline
Old 02-26-2003, 10:11 PM
  #12554
fai
Regional Moderator
fai's Avatar
Default Re: Not enough punch
- 23T Xenon motor
- GP3000 and GP3300
Raymond, I don't know the internal gear ratio of TBII but your final gear ratio with 23T should be ~4.9->5.3 just like DTM mentioned before! So, in your case, you may use smaller pinion in order to gain some torque... On the other hand, you can also use a spur gear as large as possible! (Oh, don't be too large and come out of the chasis!) Hope this helps!
fai is offline
Old 02-26-2003, 10:12 PM
  #12555
fai
Regional Moderator
fai's Avatar
Oops, Raymond: forget to say: how about charge at larger Amp of your batt. and use a more punchy mode of your ESC!!??
fai is offline
