HK Talk Version 1.1
Old 10-11-2001, 05:34 AM
  #1186
dtm
dtm's Avatar
Mars: Just checked on my RT2. Lights go out at 0.4-0.6v. After lights are out for 3 minutes cell voltage is around 0.1v. After another 10 minutes it is around 0.05v.... it then takes even longer to get to 0.02v (I measured this after leaving it overnight).
dtm is offline
Old 10-11-2001, 08:11 AM
  #1187
Mars's Avatar
Thumbs up
dtm: thanks for your info how much is the RT2 now?
BTW, I got the Mars AM module for controlling the miniZs with my Mars
Mars is offline
Old 10-11-2001, 09:06 AM
  #1188
KY9fat's Avatar
Originally posted by dtm
KY- I'm changing motors for Friday, will be running my Maxtec 11x3... will you join me!?!
I'll bring it along together with my 8x2..7x2....6x1.......Brushless.....Honda civic VTEC..
KY9fat is offline
Old 10-11-2001, 09:57 AM
  #1189
dtm
dtm's Avatar
Price is slightly above $300, you should be able to get it for less than that mark.
Be careful about running anything except the mini-z with the AM module. Last time I ran the micro with an AM module I found that the size of PYC is about the limit for the range! It should be no problems with the mini-Z F1 though because at that distance you can't see the car! Using the MARS for the mini-z adds a whole new dimension to mini-z!!
dtm is offline
Old 10-11-2001, 09:59 AM
  #1190
dtm
dtm's Avatar
Ah Ying said he will go to PYC tomorrow...... I've switched back to my Corally!!!!!!
dtm is offline
Old 10-11-2001, 06:18 PM
  #1191
Mars's Avatar
dtm: thanks again using the MARS with miniZ is really much better then the included TX. The 22 models memory of my MARS 98LE is now very useful
Mars is offline
Old 10-11-2001, 06:24 PM
  #1192
Mars's Avatar
BTW, I started the 2nd cycle on the HVs, the results amazed me. the cells now peak at ~1.56v, IR remain the same, runtime increased by ~10sec, and ave volt is now 1.172v!!! This is the best volt you can get from Trinity Team SMH cells! I think the 1st cycle show lower numbers is because its the first cycle after zapping.
Mars is offline
Old 10-11-2001, 06:46 PM
  #1193
Regional Moderator
disaster999's Avatar
Mars: dont you have work? or you have the charger and stuff in the office?? ehehehhehe
disaster999 is offline
Old 10-11-2001, 07:38 PM
  #1194
Mars's Avatar
999: I did the test at night. gone thru several cells each night and I can just remember the numbers It's not possible for me to do such thing at work
Mars is offline
Old 10-11-2001, 09:34 PM
  #1195
fai
Regional Moderator
fai's Avatar
Mars: Oh, your results are exactly the same as Uncle Chan told me...
fai is offline
Old 10-11-2001, 10:46 PM
  #1196
Mars's Avatar
fai: where are you going tonight? I am still thinking between PYC and EGR
Mars is offline
Old 10-11-2001, 11:06 PM
  #1197
fai
Regional Moderator
fai's Avatar
Mars: I think I can only go to Kai Tak... I cannot leave office early these days...
fai is offline
Old 10-11-2001, 11:18 PM
  #1198
Mars's Avatar
guys, go check out Tamiya japan site. The hobby show new products info are there. The TB Evo II is a much improved version. The Dynastorm look so nice Even the tamiya bus is very attractive
Mars is offline
Old 10-11-2001, 11:59 PM
  #1199
over gear's Avatar
Trader Rating: 17 (100%+)
who can read japanese? is the new Z body from Tamiya just a one-made for hobby show?
over gear is offline
Old 10-12-2001, 12:27 AM
  #1200
i'll be getting my EVO2 when i come back in Xmas break
Mars, dtm, fai and others that i met in PYC... dont left me out this time... i will be ready, so watch out!
ME-student is offline
