HK Talk Version 1.1
Old 09-21-2002, 09:01 AM
  #11356
KY9fat's Avatar
Originally posted by dtm
I remembered to take the shafts....but I forgot to leave them with 3P...ooops..sorry.....I'll drop them off at Harmony tommorrow since I will be going past MK!
Did you guys pick up my Solder Iron last night???? I left it behind "Jong Sow Low"
KY9fat is offline
Old 09-21-2002, 09:14 AM
  #11357
Manticore's Avatar
I didnt !! I went to PYC today only !
Manticore is offline
Old 09-21-2002, 10:01 AM
  #11358
Fire's Avatar
Originally posted by M 5
Can i charge it in 8 because I can't think of anything that holds 4 batteries...
what should i set for volt threshold and should i use NiCd Linear mode and 1.5A for charging?
Thanks!!
if your power supply can pumps out 14-15Volts then you can charge 8 cells in series at once
Fire is offline
Old 09-21-2002, 10:10 AM
  #11359
Manticore's Avatar
Tks bud, I will pick it up tomorrow at harmony.
Old 09-21-2002, 06:01 PM
  #11360
ernestf's Avatar
anyone know where i can find Xpress tires in HK ? I mean the belt tires and has the label (ISTC 00) and (POK-2000) on the tires, it is slick tires without thread.
ernestf is offline
Old 09-22-2002, 12:10 AM
  #11361
dtm
dtm's Avatar
That took you a long time to figure out.....we have sold it already!!
dtm is offline
Old 09-22-2002, 05:45 PM
  #11362
ernestf's Avatar
Finally, I tested run the GP 3300 on SG track.
I ran it once on Sunday visit. Charge it using Pitbull, 5A, 28mv cut off for first charge, repeak at 32mv cut off. The pack feel a little bit warm, only a little bit. Capacity show around 34xx which didn't seem "superb".
The cells are punchy, with my YM34 + Yokomo 10x2, gear at 1:8.03. All my other packs (HV, SMH, Powers 3000 ...) give average 7.5-8 min of run time before it slow down. GP3300 give 8.5 min of run time ! And it take almost 15 mins on the Trinity discharge tray after run while other 3000 packs only light up for a few mins after run.
With GP 3300, my YM34 weight at 1557g, which is 2x g over the standard config with HV cells. But consider its performance and the extra one minute run time, they worth the penny !
I will collect some more info such as peak volt next time.
ernestf is offline
Old 09-23-2002, 06:06 AM
  #11363
dtm
dtm's Avatar
ernestf- yes the GPs are around 30g over the SMH.......for a 6 pack!
Why do you repeak? run them straight off the first charge....
dtm is offline
Old 09-23-2002, 06:46 AM
  #11364
ernestf's Avatar
dtm, i've to pre-charge 8 packs in Fri / Sat night and re-peak it in the morning before i visit the track. there is no power supply in local SG track ! what can i do ?
ernestf is offline
Old 09-23-2002, 06:56 AM
  #11365
dtm
dtm's Avatar
Oh dear...you have a BIG problem.......buy yourself a truck 12v battery and a cart with wheels to pull it along!
dtm is offline
Old 09-23-2002, 07:01 AM
  #11366
ernestf's Avatar
haha that's too trouble, my way is :
/1. pre-charge in the previous night
/2. peak in the early morning
/3. run to the track (by taxi !!) as fast as i can
/4. play hard !
haha
ernestf is offline
Old 09-23-2002, 08:24 AM
  #11367
dtm
dtm's Avatar
"early morning".......what's that?????
dtm is offline
Old 09-23-2002, 09:29 AM
  #11368
ernestf's Avatar
so u treat your GP3300 the same way as i did ?
ernestf is offline
Old 09-24-2002, 09:01 AM
  #11369
Manticore's Avatar
Originally posted by Manticore
How about this?
Old 09-25-2002, 01:01 AM
  #11370
PeterCheung's Avatar
How about this?
Cool
PeterCheung is offline
