HK Talk Version 1.1
Old 09-18-2002, 08:16 AM
  #11311
dtm
dtm's Avatar
Originally posted by Manticore
sounds very complicated !!
Nah......the only problem I may have is that my shocks may be too "springy" on full compression........the shock in this config almost gets to full compression.....I will see!!!
dtm is offline
  #11312
dtm
dtm's Avatar
why saturday is no good?? i want to kick ass !!
Everybody having dinner with family!!!
dtm is offline
Old 09-18-2002, 08:21 AM
  #11313
Manticore's Avatar
I want to have my family BBQ there !
Manticore is offline
Old 09-18-2002, 08:22 AM
  #11314
dtm
dtm's Avatar
I'm sure your wife would NOT be impressed!!!!!
dtm is offline
Old 09-18-2002, 08:24 AM
  #11315
Manticore's Avatar
this will be big problem. when full compression, the bladder will break !
Old 09-18-2002, 08:26 AM
  #11316
dtm
dtm's Avatar
Cause I running short shaft with long body.....the piston does not get anywhere near the bladder....also I am using Kyosho bladder not the crappy Serpent bladders!!!
dtm is offline
Old 09-18-2002, 08:31 AM
  #11317
Manticore's Avatar
so, you use the new cap, metal body, front shaft, alloy spring retainer for rear?? with kyosho bladder?
Old 09-18-2002, 09:35 AM
  #11318
dtm
dtm's Avatar
No lah.....Old cap, Kyosho bladder, long Serpent body, Old front shaft, alloy spring holder and Xray ballend!!!!!!!!
Alloy body has gone to KY!!!!!!
oh...almost forgot....and a bit of Blu Tac!!!!!
dtm is offline
Old 09-18-2002, 09:41 AM
  #11319
Manticore's Avatar
how about the front shock???
what do you need blu tac for shock building??
Old 09-18-2002, 09:50 AM
  #11320
Fire's Avatar
Originally posted by ernestf
in your calculation, i have HK$ 15k worth of batteries here in SG ...
sigh, canada is hopeless
Fire is offline
Old 09-18-2002, 09:53 AM
  #11321
Fire's Avatar
If you like rust......some of that brown certainly don't look like heat discolouration (look closely at the name plate weld!).......
i like it coz it's not in some candy color
Fire is offline
Old 09-18-2002, 10:58 AM
  #11322
dtm
dtm's Avatar
OK....I can live with that....but it still won't go on my car!!!
dtm is offline
Old 09-18-2002, 11:01 AM
  #11323
dtm
dtm's Avatar
The air gap above the badder is too large on the Serpent shocks....normally you will get zero rebound from the fluid...if you fill the top half with Blu Tac there is less air so greater compression and rebound!! I like putting oil above the badder best...but this only last for a few runs!! Similar effect to using O rings above badder!!
dtm is offline
Old 09-18-2002, 11:02 AM
  #11324
dtm
dtm's Avatar
Front shock std.....but with alloy spring holder so I can use the same length spring front n back!
dtm is offline
Old 09-18-2002, 08:29 PM
  #11325
Manticore's Avatar
test
