HK Talk Version 1.1
Old 08-09-2002, 05:26 AM
  #11071
dtm
dtm's Avatar
Originally posted by Manticore
http://www.teamxray.com/teamxray/sho...b3a1a00f1bc48c
the hubs look very cool. I wonder why they didnt use the spring steel axle.
Yes the finish is excellent!! I see that they have done a mod in the back already to shorten the rear turnbuckles...that carbon piece on top of the rear hubs are non-std!!!
dtm is offline
  #11072
dtm
dtm's Avatar
Originally posted by Diva
Oh does it mean that the 3x2 chassis for saddle packs is better than the 6x1 one?
Always has been and always will be!!! Especially on the Xray!!!!
dtm is offline
Old 08-09-2002, 05:28 AM
  #11073
dtm
dtm's Avatar
Originally posted by Tommi Makkinen
by the way, dtm, what store sells the 201 you said is worth HK$9xx?
Most stores have them at around that price! No one in particular!
dtm is offline
Old 08-09-2002, 05:29 AM
  #11074
dtm
dtm's Avatar
Originally posted by ernestf
diva, yes i agree that the 414 chassis has better centralized placement of 3x2 batt. but over-centralized batt placement might not be an absolute advantage tho. look at the original version of kx1. well, after re-think twice, i decide to go with typical 3x2 placement on my xray
If you are running on small tight track, try the left hand pack one cell forward!!
dtm is offline
Old 08-09-2002, 09:56 AM
  #11075
dtm
dtm's Avatar
Thats another interesting point....he seems to be running fixed pullies on the centre layshaft!!
Are you regretting getting rid of your Xray Mr Manticore??
dtm is offline
Old 08-09-2002, 10:12 AM
  #11076
Manticore's Avatar
I dont have time to get rid of it !! too bad !
Manticore is offline
Old 08-09-2002, 11:11 AM
  #11077
dtm
dtm's Avatar
So now you have even more options on the car you do not run???!!!!
dtm is offline
Old 08-09-2002, 11:14 AM
  #11078
Manticore's Avatar
how much did you pay for the c hub conversion?? xray said that this is for carpet??
the hubs come with the c-hub? or different packing?
Old 08-09-2002, 11:31 AM
  #11079
dtm
dtm's Avatar
List price is $1280...you can work out your discount!
They are packaging both front and rear conversion together.
You get;
Front set:
Alloy C bracket,
Alloy hub
A-arms
hinge pin
Turnbuckle
Driveshaft (same as rear)
Axle (same as rear)
Front shock tower
Rear set:
A-arms
Alloy hubs
turnbucckle
hinge pins
Hinge pin holder (for rear toe in)
dtm is offline
Old 08-09-2002, 11:35 AM
  #11080
dtm
dtm's Avatar
Also, the C bracket is 3 deg caster.......which means there will be additional options later!!!
dtm is offline
Old 08-09-2002, 08:41 PM
  #11081
ernestf's Avatar
3 degree, that is good for tight track
ernestf is offline
Old 08-10-2002, 10:00 AM
  #11082
Diva's Avatar
Trader Rating: 14 (100%+)
Ummm. My next target.
Diva is offline
Old 08-10-2002, 10:03 AM
  #11083
dtm
dtm's Avatar
We went to Gold Coast today....you did not say that the life guards do not allow RC Surfers!!!!!
dtm is offline
Old 08-10-2002, 08:56 PM
  #11084
ernestf's Avatar
i have broken my YM34 front univ shaft, 6mm one-way outdrive and steering block yesterday. so far no luck in any SG tracks ! 36R does not work well here, track surface is lack of traction seriously ....
ernestf is offline
Old 08-10-2002, 09:08 PM
  #11085
dtm
dtm's Avatar
Ouch! That was a big hit!! Try HPI 33R when Sorex 36R fails!!! Was you using any traction compound on the 36R??
dtm is offline
