HK Talk Version 1.1
Old 07-24-2002, 05:40 AM
  #10816
Manticore's Avatar
Originally posted by dtm
Hey Manticore- Theres a load of bits arrived for that Kawa clutch of yours at PG tonite. They are supposed to be "options" .......but I wouldn't know!!!
i still havent put my SS clutches on !!
Manticore is offline
  #10817
Manticore's Avatar
MK is out of 15T!!!!
next week !
Old 07-24-2002, 05:43 AM
  #10818
dtm
dtm's Avatar
In that case you can put the "options" on before you build!!!!
I saw the thrust brg was very cheap....only Yen 600!!! also other teeth for second gear!
dtm is offline
Old 07-24-2002, 05:44 AM
  #10819
Manticore's Avatar
deflation !!!
Old 07-24-2002, 05:47 AM
  #10820
dtm
dtm's Avatar
deflation !!!
Haha...yes you will be "screwed" on the conversion rate!!!!
dtm is offline
Old 07-24-2002, 05:51 AM
  #10821
dtm
dtm's Avatar
I finually put my money on an M'tronik Cube! What the hell!!!
dtm is offline
Old 07-24-2002, 06:05 AM
  #10822
M 5
M5- Does the car run faster with HPI tires on the right and Tamiya tires on the left???!!!
Yes, maybe?
Heres the other side of the car,
M 5 is offline
Old 07-24-2002, 06:12 AM
  #10823
M 5
Guys I have a question,
the picture below shows the clutch, something inside dropped out as I screwed of the small piece of screw. A ball and a spring dropped out. I dont know how to put it back in, please give me some advice.
thanks!
M 5 is offline
Old 07-24-2002, 06:39 AM
  #10824
dtm
dtm's Avatar
That will be your 2 speed adjuster. You should have an arm that is hinged on your clutch. At the back of it will be a hole. Put the ball in first, then the spring and then a grubscrew to hold everything in place (put thread lock on this one). Don't screw the grub screw all the way down...you will never get 2nd gear! You simply have to run the car to adjust when the 2nd gear comes in!
dtm is offline
Old 07-24-2002, 06:41 AM
  #10825
dtm
dtm's Avatar
The look of that rear drive shaft looks very "Losi SW" like!!!!
dtm is offline
Old 07-24-2002, 08:48 AM
  #10826
Diva's Avatar
Trader Rating: 14 (100%+)
Have you tried Hung Sing?
Diva is offline
Old 07-24-2002, 08:55 AM
  #10827
dtm
dtm's Avatar
Yes!........I don't need it.....I just want it!!!
dtm is offline
Old 07-25-2002, 02:45 AM
  #10828
KY9fat's Avatar
Hi Guys,
Just back from UK holiday.
Saw the Schumacher Fusion for 300 pounds in a magazine..
It comes with a 21 engine and 3 speed gear box..and can go 80mph, that is 130 kph!!
KY9fat is offline
Old 07-25-2002, 02:52 AM
  #10829
KY9fat's Avatar
Oh, and a Ferrari F201 cost 230 pounds!!!
KY9fat is offline
Old 07-25-2002, 05:45 AM
  #10830
dtm
dtm's Avatar
Originally posted by KY9fat
Hi Guys,
You and your Schmacher...........I'm still waiting for you to put the money down on one!!!
I see you finually got on the plane!!! We were thinking you got bumped off.......Going to MK to get your surfer tomorrow??
dtm is offline
