HK Talk Version 1.1
Old 06-04-2002, 02:51 AM
  #9991
Regional Moderator
disaster999's Avatar
Originally posted by ernestf
sure, i can sell you one or two 4mm one-way units in case u need it.
thanks...i just need to outdrive!!
disaster999 is offline
Old 06-04-2002, 02:54 AM
  #9992
Regional Moderator
Originally posted by dtm
No....saving private ryan copied my quotes!!!! I've been using this one since school!!!!!!!!
hahaha...really?? the fubar thing started out that long? wah..didnt know what!! i thought they made it up in the movie!
Old 06-04-2002, 03:22 AM
  #9993
Regional Moderator
hey dtm....what kind of air compressor do you use to paint your bodies? how much is it?
thanks!
Old 06-04-2002, 04:07 AM
  #9994
dtm
dtm's Avatar
thanks!
I am using the Taiwan pump that you see in some of the model shops in MK (Wing Jet, Harmony etc), I think it goes for around $6xx-7xx (I can't remember).
But using the pump alone is only so so.....I ended up buying a reservoir bottle to store the air in before getting to the gun. This makes a big difference because I can control the psi at the gun and keep this fairly constant for even painting. With just the pump, the moment you press the button the pressure will drop to the output level of the pump, no control!!
The reservoir was around $400....but well worth it!
dtm is offline
Old 06-04-2002, 04:09 AM
  #9995
dtm
dtm's Avatar
You can buy a 2 in 1 pump and reservoir...the pump is a dual compressor and gets to normal operating pressure very quickly...this is a very nice setup. I think the price is around $14xx.
dtm is offline
Old 06-04-2002, 04:17 AM
  #9996
dtm
dtm's Avatar
Originally posted by Diva
There're many guys like that out there. Ask KY for his EVO II.
KY has been very conservative with the mods on the Evo...its his F201 I'm concerned about!!!!!
dtm is offline
Old 06-04-2002, 04:21 AM
  #9997
Regional Moderator
oh...icic...but how about those japanese ones?? Mr.Color?
Old 06-04-2002, 04:23 AM
  #9998
dtm
dtm's Avatar
I haven't seen that one.....it is a real compressor or a mickey mouse one like the Tamiya piston type pump??
dtm is offline
Old 06-04-2002, 04:25 AM
  #9999
Regional Moderator
but how about the water vapor in the air? i thought theres a bottle that catches the vapor...
what are those air tanks? just mini tanks that stores air?
and how bad was the compressor without the tank? how strong was the pressure?
Old 06-04-2002, 04:27 AM
  #10000
Regional Moderator
hahaha...nono..its like those professional compressor....nothing like the tamiya one..
i have the tamiya one...and im using a 12V power supply to use it....
using 7.2V is just gives off a very weak pressure!
Old 06-04-2002, 04:28 AM
  #10001
ernestf's Avatar
diva, it is time for my Pro3 to hit the track with your xxx3 !!!
ernestf is offline
Old 06-04-2002, 04:30 AM
  #10002
Regional Moderator
hehehe..ill get my ym34 ready too..just need a shell for it....
hey...this post is the 10001st post already....hell ya!!
Old 06-04-2002, 04:35 AM
  #10003
ernestf's Avatar
i tested my KX1 in PYC today, the car still prefer a tighter belt setup for better acceleration. Due to hot weather today, i use one gear down on the pinion (1:8.48 with 8T). however, the car still dont have good acceleration and top speed. something wrong with my ESC again ???
ernestf is offline
Old 06-04-2002, 04:36 AM
  #10004
Regional Moderator
http://www.vuono.co.jp/en/sexy/tool/dougu_g1.html
these are the mr.color compressors!
Old 06-04-2002, 04:48 AM
  #10005
dtm
dtm's Avatar
Yes I have a seperate water trap...you do need it..after about 1/2 hour spraying you see a fair bit of water in there!!!
The tank is about 1.5-2 litre in size...without it you need to let the compressor 'catch its breath' after each pass if you are spraying a large area. Compressor alone is ok for detail work...but pressure is not very constant!!
dtm is offline
