HK Talk Version 1.1
Old 05-27-2002, 11:05 PM
  #9631
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Default Re: Re: Re: Re: F201 bearing
Originally posted by Manticore
use heat to melt the heavy gease instead of soak them in solvent !! works faster !! hahahaaha
hmm... methinks i'll use the solvent method instead...
Tommi Makkinen is offline
Old 05-27-2002, 11:06 PM
  #9632
dtm
dtm's Avatar
Default Re: Re: Re: Re: Re: Re: F201 bearing
Originally posted by Tommi Makkinen
your tip is similar to a tip i heard a few months ago but i was advised to use WD40 as the lube. what brand of bearing lube would you recommend?
DON'T use WD....leaves a yucky brown residue when it dries!!!!!
dtm is offline
Old 05-27-2002, 11:07 PM
  #9633
dtm
dtm's Avatar
Bearing oil- Trinity Royal oil........
dtm is offline
Old 05-27-2002, 11:08 PM
  #9634
the older version of roby charger has tickle charge. It is not really good for nimh cells !
figures... my friend did buy the upgraded version. he appreciates the warning i gave him though...
Old 05-27-2002, 11:09 PM
  #9635
dtm
dtm's Avatar
Originally posted by White cat
The Tamiya rubber seal bearings is a lot smoother than those black rubber seal bearing. Also, they are the only 100%maintance-free bearing in the market. My TA02 bearings are still as smooth as brand new.
But still more friction than the metal shield bearing with the shield removed from one side and running bearing oil!!!!!
dtm is offline
Old 05-27-2002, 11:11 PM
  #9636
unfortunately, where i live, those bearings are even rarer than the TA-02 kit itself!
Old 05-27-2002, 11:14 PM
  #9637
Default Re: Re: Re: Re: Re: Re: Re: F201 bearing
darn! thats why i it has that stuff. i gotta try something else.. thanks dtm.
Old 05-27-2002, 11:19 PM
  #9638
Regional Moderator
Don't use this oil!!!! It ruins your bearings. 5W-30 motor oil is much better.
White cat is offline
Old 05-27-2002, 11:25 PM
  #9639
Regional Moderator
Default Re: Re: Re: Re: Re: F201 bearing
You are right, but the Tamiya rubber seal bearing can keep its smoothness a lot longer than metal shield bearing.
Old 05-27-2002, 11:29 PM
  #9640
what brand? i have in 10cc bottles of Mobil1, Valvoline, Pennzoil, Castrol, and Petronas. and is it natural or synthetic oil?
Old 05-27-2002, 11:46 PM
  #9641
Regional Moderator
I use Valvoline synthetic oil, but other brands work fine as well. Just 1-2 drops per bearing is enough.
Old 05-27-2002, 11:51 PM
  #9642
Manticore's Avatar
thin based bearing lube. I put serpent one-way lube on it. very smooth
Manticore is offline
Old 05-27-2002, 11:53 PM
  #9643
Manticore's Avatar
wd40 is corrosive !!
Old 05-27-2002, 11:54 PM
  #9644
Manticore's Avatar
Yes...the cells do come off punchy......for a while!!!!!
I suspect it was just a software bug.......
i have been using 2000's with roby charger for more then 1 years and they remained punchy until the second half of second year !!
  #9645
Manticore's Avatar
and i was using them like at least once per week
