HK Talk Version 1.1
Old 05-03-2002, 08:45 PM
  #8131
dtm
dtm's Avatar
Originally posted by Manticore
that's good, you are recycling your stickpack every week
but I'm lazy and don't fully discharge every week....In fact I start charging with part charge in the Nicads........not very good for the batteries!!!!!!
dtm is offline
Old 05-03-2002, 08:56 PM
  #8132
Manticore's Avatar
I think you use 3000 nimh cells for your starter box??
Manticore is offline
Old 05-03-2002, 08:59 PM
  #8133
Manticore's Avatar
Default Kawahara Centax
Old 05-03-2002, 09:50 PM
  #8134
PeterCheung's Avatar
Default Re: Re: Re: Re: re
Manticore only likes Futabas and Sanwas.... he won't buy a KO!!!!!!!!!!
so he should use 3003....hehe
PeterCheung is offline
Old 05-03-2002, 09:51 PM
  #8135
dtm
dtm's Avatar
No lah....Sanyo 1700s...more punch!!!!!
dtm is offline
Old 05-03-2002, 09:53 PM
  #8136
but i prefer TA04 with stick pack !
can it use saddle pack with a little bit mod.?
Old 05-04-2002, 02:45 AM
  #8137
Regional Moderator
disaster999's Avatar
yupyup...just slide a saddle pack, 6x1 and solder the wires directly onto the batt...or bend the batt bars and add the corally connecters...
disaster999 is offline
Old 05-04-2002, 02:51 AM
  #8138
Regional Moderator
Biggest problem is that my only 2 stick packs is in my starter box!!!!!!
how long does your stickpacl last in your starter box?
i have a 1200 and 1400 in there..and it only starts the engine 10 times and it dies out...
Old 05-04-2002, 08:16 AM
  #8139
i prefer connect T-plug on the batt side, it is more convin...
hehehe
Old 05-04-2002, 09:10 AM
  #8140
ernestf's Avatar
ky, manticore, thanks for your help today on my SX12, after running 1 ltr of 16%, it works a bit better now. but still, hard to start and not so stable.
i will do the following to see if it can improve :
/1. parallel connect the 12V power supply to the starter box motors instead of serial connect.
/2. open the engine, and clear it using motor clear, then re-lube it using after run oil
/3. add a 1.5mm shim to the engine
i did also find an old piston (from my RB X12 turbo) which can be replaced too, but let's see if the above help !
ernestf is offline
Old 05-04-2002, 09:55 AM
  #8141
dtm
dtm's Avatar
I get at least a days run.....unless I am running in a new stubborn engine!!!
dtm is offline
Old 05-04-2002, 09:58 AM
  #8142
dtm
dtm's Avatar
You found a source for replacement pistons???? where? where?
I think it is such a big rip off having to buy sleeve and piston in one set.....don't believe for a minute that they are 'matched' just compare my 'matched RS' and my 'matched RB 5 port' both ran 5 tanks and were as loose as hell!!!!!! ( good compression but no piston lock!!! )
dtm is offline
Old 05-04-2002, 09:59 AM
  #8143
dtm
dtm's Avatar
Arsenal won the FA cup.......................Yer!!!!!!!!!!!!!!!!!
dtm is offline
Old 05-04-2002, 10:06 AM
  #8144
dtm
dtm's Avatar
I tell you.....my Alfa really does have 'SOUL' ......on the way back from PYC it decided to play up....I think it knows I am trading it in!!!!
The cooling fan stopped working and the car almost overheated. Played about with the sensor connectors and it was ok again. The really wierd thing was that I was going through Wan Chai at the time. With my first Alfa 164/8 I had exactly the same problem....at exactly the same point on the road. Tonight I stopped the car at exactly the same spot!!!!!! This is exactly the same problem on two different cars occurring at exactly the same patch of road....with about 3 years in between the incidents..........I think I am going to buy the mark six on Monday!!!!!!!
dtm is offline
Old 05-04-2002, 10:17 AM
  #8145
ernestf's Avatar
i used to have a car with soul few yrs ago, its power window, air-con, .... all having problem in its 3 yrs old. by that time, i know alfa is not for me.
ernestf is offline
