HK Talk Version 1.1
#7096
Originally posted by dtm
Plastic hubs F/R
Pivot balls x4
Pivot ball holders x4
Hub bearings x8
RR rear wheel drive cups x2
V1 front drive cups x2
V1 Wheel hex x4 (just get the plastic ones from V1R driver who has upgraded to alloy!)
V1 front drive shaft x2
Use the normal MTX drive shafts for the front but with no O rings.
Use the V1R (normal) Front drive shaft for the rear, use 1 O ring.
Plastic hubs F/R
Pivot balls x4
Hub bearings x8
#7097
Originally posted by KY9fat
Pivot ball X 8!
Pivot ball X 8!
#7098
Originally posted by Jean Alesi
Hey guys, I'm driving a Mission now.
What hop ups did you add to your standard kit If any?
Also, how much is the mission anyway?
#7099
In that case you only need the stuff for the back!!! My list is for all four corners!!
1) F/R rear hubs
2) 4 x pivot ball
3) 4 x bearing
4) 2 x outdrive
5) 2 x wheel hex adapter
6) 4 x pivot ball holder
can i use MTX dog bones for the rear? too long or too short?
#7100
But Type T is Japanese!!!!.......I'm looking at the Alex Barracuda.....anyone know MK prices????
#7101
Originally posted by hurhur
so what i need is the following
1) F/R rear hubs
2) 4 x pivot ball
3) 4 x bearing
4) 2 x outdrive
1) F/R rear hubs
2) 4 x pivot ball
3) 4 x bearing
4) 2 x outdrive
You cannot use the MTX drive shaft...it makes the car like 202mm min with no O-rings!!! The V1R drive shafts are just right! I used RR rear drive shafts and ended up with 3 O rings on each side!!
#7102
dup post
#7103
Is the Barracuda for CC or You just want to run over ah ying
#7104
KY- You're out of luck with your F201....price is Y15000.......
#7105
#7106
You got A runner-up and TQ...
#7107
That's 900 if exch. is 0.06..and with a 5% discount.......HeHeHe..
#7108
You only need R hubs.
#7109
the normal V1R outdrives will do right? dont need the wide outdrives right?
#7110
Oh...the other thing is that the V1R Rear hubs go on backwards....Left to right etc.....
