HK Talk Version 1.1
Old 03-20-2002, 06:29 AM
  #6736
ernestf's Avatar
if the FAST/Ellegi 30mm rear tires are cheap and do the work correctly, why brother to play around with the more expensive (double the price) ZACS 32mm ??????
ernestf is offline
Old 03-20-2002, 07:50 AM
  #6737
dtm
dtm's Avatar
Originally posted by hurhur
Zacs are expensive? So Ellegi and Fast 30mm shld fit on your MTX w/o any problems rite? So in your opinion, do u think Zacs can fit the MTX?
Just see if they are offset! If they are then it won't be a problem!!!! Alternatively, find someone at your track who uses ZAC in the V1RR, because they Kyosho conversion will make the wheel fitment same as V1RR!!!! Why you do want to buy 'expensive' tires anyway???
dtm is offline
Old 03-20-2002, 07:51 AM
  #6738
dtm
dtm's Avatar
30mm 0mm offset FAST and Ellegi fits fine!
dtm is offline
Old 03-20-2002, 07:52 AM
  #6739
dtm
dtm's Avatar
Originally posted by Diva
But a lot harder rims
You only use them for 1 day...or 2 days max......don't worry too much about harder rims.....they will just crack instead of bend!!
dtm is offline
Old 03-20-2002, 09:20 AM
  #6740
Diva's Avatar
Trader Rating: 14 (100%+)
Just back from MK today. Everybody is talking about the Baracuda from Team Alex now. Some water goods were imported and cleared. Perhaps another good try after TC3.
ernestf: are you talking about the new yokomo "S" series? I got a 9x3 and will test it on Friday night. Will you be interested to gear up you kx-1?
Diva is offline
Old 03-20-2002, 09:20 PM
  #6741
ernestf's Avatar
diva, yes, i am using the yokomo S 10x2. i am not sure if i has triple wind version.
i'm still running my old YM34 lately, not the KX1.
i have to check with my boss first to see if i can join u on Fri nite.
ernestf is offline
Old 03-21-2002, 09:44 AM
  #6742
hurhur's Avatar
"I drive a MTX2-Pro, and I have been upgrading it with Kawahara parts.
Recently I bought the narrowed rear suspension kit, K-740. The kit
comes with dogbones, arms, axles, and hex drives. When installing I
found that the lower arms were the same size as the stock ones. A
friend that has them as well measured his and found the Kawa's to be
1/8th inch smaller. Then, as I got further along, I found that the
dogbones, that are shorter, were too small, and as I rotated the rear
tires the dogbones would slide out of the axles. Solution: put the
stock ones back in... then when I put the new larger hex drives on the
tires were way wider than the 200 mm max width. Solution: use the stock
purple hexdrives back on... it almost appears that the 32 mm wide rear
tires would have fit without all this stuff. Anyone else have problems
like this?"
read this from the starting grid forums, whats your opinion Manti since u own one.
hurhur is offline
Old 03-21-2002, 09:48 AM
  #6743
Manticore's Avatar
like this?"
he could have done something wrong ! the derlin or "machined nylon" arm is shorter then the stock arm. dont have any problem as described above.
did he really got a kawahara kit or it is a GPM kit?
Manticore is offline
Old 03-21-2002, 09:52 AM
  #6744
hurhur's Avatar
he said its the Kawa set in the posting.
hurhur is offline
Old 03-21-2002, 07:59 PM
  #6745
ernestf's Avatar
i have the kawa kit on my MTX2 too, but not the full kit. just the derlin rear arms, new outdrive with the longer hex. i use the stock dog bones without any problem. i use 26mm foam in front, and 30mm in back.
i have 199mm track base both front and rear.
ernestf is offline
Old 03-21-2002, 11:23 PM
  #6746
hurhur's Avatar
the new outdrive for the Kawa set is longer so that you can fit the Kawa wide hex and leaving enough threads on the outdrive to secure your wheel tightly?
hurhur is offline
Old 03-21-2002, 11:34 PM
  #6747
ernestf's Avatar
of cuz.
ernestf is offline
  #6748
Manticore's Avatar
Yes
Old 03-21-2002, 11:35 PM
  #6749
Manticore's Avatar
Originally posted by ernestf
of cuz.
have you prepared a VDS body for tomorrow?
Old 03-21-2002, 11:44 PM
  #6750
hurhur's Avatar
wats on for you guys tomorrow? sounds interesting
hurhur is offline
