HK Talk Version 1.1
Old 03-17-2002, 05:49 AM
  #6571
dtm
dtm's Avatar
Originally posted by Manticore
I am using that taiwan one but it is not cheap tho.
You are asking a lot for $4x !!!!!!
dtm is offline
Old 03-17-2002, 05:51 AM
  #6572
dtm
dtm's Avatar
Originally posted by hurhur
dtm,
have u tried fitting Zac 32mm rear tires to your MTX which uses the V1RR hubs? will they fit?
I have only been using the 30mm FAST and Ellegi tires....they give me more than enough grip already!
dtm is offline
Old 03-17-2002, 05:53 AM
  #6573
dtm
dtm's Avatar
the solid axle is cheap and light weight but havent tested it yet
After snapping the K factory alloy 2 speed shaft.....I am having second thoughts about those 'thin' shafts in my drive train!!
dtm is offline
Old 03-17-2002, 06:44 AM
  #6574
Manticore's Avatar
Originally posted by dtm
No, it was those movable triangular barriers they use. On the first count my car crept up onto one of those and because they were not exactly aligned....it took a big chunk off my bumper. On the second occasion it was worse.....full speed down the straight and I got a little close to the end of those barriers again......full speed to zero in about 2 feet....that was how far I managed to kick one of those barriers with my RR!!!
Have bought the kawa and original v1 bumper.....it should work!!! I can combine the two together using the front body mount post holes...this will give it much more strength....you should consider it Manticore!!!
haha, great story. I am quite happy with the kawahara bumper alone. i do crash but not as serious as yours.
Manticore is offline
Old 03-17-2002, 06:45 AM
  #6575
Manticore's Avatar
manti,
u using the kawahara rear arm set for MTX? how is it? any feedbacks?
the finishing of the arms are top notch. very light weight. you still need a 0.5mm shim so that you can use 30mm rear rims.
Old 03-17-2002, 06:47 AM
  #6576
Manticore's Avatar
But it has special K Facotry drive cups...when they wear...you throw away the solid shaft!!!
I consider this unit is cheap when you have everything you need for solid axle. just buy another one. the kawahara adaptor does wear at the cross pin area after excessive runs.
Old 03-17-2002, 06:48 AM
  #6577
Manticore's Avatar
of cuz, how many time you affix a flywheel? i used it a couple of times only and it is already 4x !!
Old 03-17-2002, 06:50 AM
  #6578
Manticore's Avatar
haha you made this mistake at the first place to use K factory alloy main shaft. I wont do that.
Old 03-17-2002, 07:00 AM
  #6579
hurhur's Avatar
u mean u had to shim the hex nut in order to run 30mm foams? i thought it can take Zacs 32mm, so 30mm shouldnt be a problem.
hurhur is offline
Old 03-17-2002, 07:03 AM
  #6580
Manticore's Avatar
i mean i need to add a 0.5 shim to make 30mm rim fit on the axle. you can use brokomo 32mm rear rim without modification as it is 2mm offset rim.
Old 03-17-2002, 07:06 AM
  #6581
hurhur's Avatar
the material used for the conversion arms is delrin? have u tried Zacs before?
hurhur is offline
Old 03-17-2002, 07:10 AM
  #6582
Manticore's Avatar
yes, it is black derlin. or they call it machined nylon.
i have a set of ZAC tire but havent tried it yet. the shore front and rear are very much different so I am not interested to test it out anytime sooner.
Old 03-17-2002, 07:13 AM
  #6583
hurhur's Avatar
manti, have u seen a Kawa MTX solid axle before? does it come with the cup joints and pulley?
hurhur is offline
Old 03-17-2002, 07:17 AM
  #6584
dtm
dtm's Avatar
I noticed the K factory blue rear gear is also available now.....it would have saved me buying a full set of Kyosho had it been available earlier!!!!
dtm is offline
Old 03-17-2002, 07:18 AM
  #6585
dtm
dtm's Avatar
You'll be needing it again to change those bearings!!!
dtm is offline
