HK Talk Version 1.1
Old 03-04-2002, 09:29 AM
  #6391
dtm
dtm's Avatar
hurhur...you are using the upper hole on the A Arm to mount the ball end aren't you??
dtm is offline
Old 03-04-2002, 09:30 AM
  #6392
Manticore's Avatar
Originally posted by dtm
A arms sit almost horizontal when shocks are fully extended...I am using the lowest hole on the shock tower...that should give me less downstop.....if I remember correctly!!! where are you Manticore.....??????
sorry i am using kawahara short rear a-arm conversion !!
Manticore is offline
  #6393
hurhur's Avatar
u are rite!
hurhur is offline
Old 03-04-2002, 09:32 AM
  #6394
Diva's Avatar
Trader Rating: 14 (100%+)
Do you think I can send this servo to World for repair??
You'd better make a fried omlette with it.
Diva is offline
Old 03-04-2002, 09:35 AM
  #6395
Diva's Avatar
Maybe the failsafe unit needs a failsafe!!!
Aaah, that's an A-level pure math question - what the hell is "failsafe square"
Diva is offline
Old 03-04-2002, 09:36 AM
  #6396
dtm
dtm's Avatar
Originally posted by hurhur
u are rite!
It easier to explain with a pic...heres the back end of my MTX with the shocks extended.....does yours look like this???
Ignore the hubs....they are V1R hubs!
dtm is offline
  #6397
hurhur's Avatar
dtm, u using the lower hole to mount the ball end?
hurhur is offline
Old 03-04-2002, 09:38 AM
  #6398
dtm
dtm's Avatar
.......double the money...four times the protection.....and a car that doesn't move!!!!!!!
dtm is offline
Old 03-04-2002, 09:40 AM
  #6399
dtm
dtm's Avatar
A man with too much money!!!!!!
dtm is offline
Old 03-04-2002, 09:42 AM
  #6400
hurhur's Avatar
y do u use V1R hubs on your MTX?
hurhur is offline
Old 03-04-2002, 09:44 AM
  #6401
dtm
dtm's Avatar
Yes..it is easier to install wide foam tires!! if you notice, the wheel hex is offset...this is from the RR..you can get wide foam tires on without having to cut the hub or spending on the Kawa conversion!!
dtm is offline
Old 03-04-2002, 09:46 AM
  #6402
dtm
dtm's Avatar
oops...the pic doesn't actually show that part too clearly!!
dtm is offline
Old 03-04-2002, 05:48 PM
  #6403
Manticore's Avatar
failed safe = RC domdom ??
Old 03-04-2002, 08:49 PM
  #6404
Diva's Avatar
...and omelette...
Diva is offline
Old 03-05-2002, 03:58 AM
  #6405
ernestf's Avatar
http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1711157071
someone is tired of the big name GP car after only 1 month ....
ernestf is offline
