HK Talk Version 1.1
#527
Originally posted by over gear
the Jet Micro graphite chassis is too thick! can't fit the battery holder...
hint. You want to be doing this before you install the upper deck onto the car!
Another more troublesome method is to take a dremel to the upper deck. 30 secs spin should do the job!
#528
Originally posted by KY9fat
Also some foam on the bottom plate to hold them inplace. Just in case DTM ram me from the side
#529
Does any micro owners find their micros have different left and right turning radius? my car's left turn is much tigher than right turn with standard futaba servo and hitec mini servo, did i miss something important when building the car?
#530
I've just got a Mini Z F1 given to me as a present! Besides the obvious ... like tires, bearings,Xspeed motor... what other options do I need for this car?
Also, what combination of tires is everyone running on carpets?
One other thing... is it me or does the front suspension bind up on the F1... I'm also thinking of getting the steel front hinge pins.
#531
Regional Moderator
DTM: You bought yourself a birthday present??? Really cannot not help you about the settings of F1...
#532
#533
#534
i found that it's due to that steering rod, the place it holds onto the servo horn bottoms out when turning right making the rod itself part of the suspension and make the sus almost twice as stiff. maybe i use use a normal servo saver and tie rods to replace that thing.
#536
Regional Moderator
i want traction roll too!
how to soften the rear end with the graphite chassis? too stiff now!
#537
Originally posted by Manticore
Grease the kingpin !!
#538
Tried that.... it seemed to make things worse! I think it is the black coating on the kingpins that is rough!
#539
#540
Use thick silicon oil. doesnt matter Black or Silver !!!!
