HK Talk Version 1.1
#5086
Originally posted by Manticore
i do think the TR heatsink is for plane !
#5087
i never have problem with the stock screws ! i have a cheap but good tool for the screws !
#5088
Originally posted by dtm
KY has found this problem before with the end cap screws..... but so far so good for me... touch wood!!!!
you see now the novarossi has almost 3HP for the same spec engine but it still uses the stock screws without having much headache with the screws !
#5089
Does this mean my TR will FLY????!!!!!
#5090
Bath time for me!!!! Good nite!!!
#5091
Hang on... didn't we have this conversation about a month ago?????!!!!!
#5092
If you ever heard of KB engines (1hp) , you should know in old days those yankee used cap screws and drill a small hole across the cap and secured the screws in place with thin piano wire !
#5094
I know your car will fly when it hits something ! hahahaha (cant stop laughing)
#5095
I will know the TR is more powerful than the MT when it has beaten the MTs current high jump record!!! Clearing the RR OVER the fence at the end of the straight at PYC!!!!!!
Turbo for rent !
#5096
Regional Moderator
What have you done???? I have a MT with about 5 gallons under its belt still running strong. I expect this to die a 'glorious death' any time now but it just keeps on surprising me!!!
#5098
I tried the 3 damper setup when EGR was new..... it was ok... turn in was too sharp for EGR but PYC 'maybe' OK!!! I used to run Tamiya Medium friction damping grease on the RC12 this 'fixed' the rear end more than the 3 dampers. I won't be running RC12... yet... so we can all have a laugh if it doesn't work out!!!!
I will go playing this Friday night instead of Sat...playing golf instead.. If it rains again, me and Mr. Dick will go to EGR and play on the small track. Also we will run our 1/18 micro...Any body interested?
#5099
#5100
Originally posted by KY9fat
I'm also changing back to stock screws too.. the take-off screws are too hard and I have ripped a thread on one of my MT case Also for the "Mei Come" the 4 screws there are not quite 2.6mm. its slightly larger and we have been fitting 2.6mm scres!!
