HK Talk Version 1.1
Old 09-18-2001, 08:18 PM
  #496
Manticore's Avatar
Originally posted by fai
DTM: Your friend is right!!! My zapped Sanyo 3000 can only charge to 2400mah after its first run!!!
Ernest: No matter what's the result is, thanks for lending me the zapper...
You might have done something wrong with the zapper.
Manticore is offline
Old 09-18-2001, 08:27 PM
  #497
Manticore's Avatar
Originally posted by ernestf
fai, the secret is :
(1) never let her know where the cars located
(2) just take out one car at a time to work on
(3) never explain what is the difference between engine and motor
and the most important point - spend more $$ on her than your RCs
Does this theory apply to ......................
  #498
Manticore's Avatar
manticore, yeah, let's bigfooting this weekend !
Sunday? lets BBQ the same time !!
Old 09-18-2001, 08:28 PM
  #499
Manticore's Avatar
Originally posted by dtm
Triple WOW WOW WOW!!
Triple WOW WOW WOW + 1
Old 09-18-2001, 08:36 PM
  #500
ernestf's Avatar
fai, i am sorry to hear that .......
i guess you won't do any zapping any more ......
ernestf is offline
Old 09-18-2001, 09:46 PM
  #501
dtm
dtm's Avatar
That "most important point" is the one that hurts your pockets most!
Fai: Sorry to hear about your batteries.
Mars: Are your smh the loose cells selling in MK now? I would be interested in the results too... I thought these cells were already zapped?!
dtm is offline
Old 09-18-2001, 10:03 PM
  #502
fai
Regional Moderator
fai's Avatar
Mars/Manticore: I just zapped them with about 40V. I think my 3000s are too old to withstand zapping!!
DTM/Ernest: Now, I have excuse to buy more new packs!!!
fai is offline
Old 09-18-2001, 10:42 PM
  #503
Mars's Avatar
dtm: yes, I am processing the loose smh cell I bought in MK. I zapped them, rested one day, then started the first cycle 2 days ago. I won't take the results of this cycle because its just the first cycle after zapping. I plan to do one more cycle thru each cell and use the results of this cycle to do the matching. Though I didn't use the first cycle data, typical figures are 1.15xV , 18-19IR, 520-530 sec. I discharge at 20A and cutoff at 0.9V.
Mars is offline
Old 09-18-2001, 10:45 PM
  #504
Mars's Avatar
fai: some of my oldest Sanyo cells also died after zapping. I think its because the cells are too old (very first batch sanyo3000 available in HK) and that I didn't give them enough time to stablize before charging again.
Mars is offline
  #505
dtm
dtm's Avatar
fai- Haha... buy some smh while you can. I just ran one cycle of the new smh pack I got. Runtime appears to be lower (535s) but voltage appears to have gone UP! 6.90v avg on 20A discharge. This is just the first cycle so time will tell.
Also, one thing that surprised me was that the charge capacity was 3015mah and discharge capacity was 2972mah.... very close indeed!
dtm is offline
Old 09-18-2001, 10:47 PM
  #506
dtm
dtm's Avatar
These initial results appear to be very similar to what I'm getting with this batch of smhs..... I'm tempted to buy one more pack just to confirm!
dtm is offline
Old 09-18-2001, 11:52 PM
  #507
Regional Moderator
SMH perform better at the second charge in the same day.
White cat is offline
Old 09-19-2001, 12:21 AM
  #508
Manticore's Avatar
all nimh have this characteristic. PAN 1700mah nicad cells have this characteristic too.
Old 09-19-2001, 12:49 AM
  #509
over gear's Avatar
Trader Rating: 17 (100%+)
Thumbs down
the Jet Micro graphite chassis is too thick! can't fit the battery holder...
over gear is offline
Old 09-19-2001, 01:20 AM
  #510
Regional Moderator
hehehehe
