HK Talk Version 1.1
Old 01-27-2002, 07:51 AM
  #5041
Manticore's Avatar
Originally posted by dtm
Yes... even with my NR CX12 it was a struggle getting top end power out! Thats why OS have always never been there on top! I will let you know how the TR performs in a couple of weeks (after ANOTHER run in!!! )
yeah looks like the weather only allows us to run in engines !!
I am considering another engine now ! what should I get?
Manticore is offline
Old 01-27-2002, 07:52 AM
  #5042
Regional Moderator
disaster999's Avatar
Originally posted by Manticore
It wont work with 3 dampers for asphalt. the side damper will make the rear suspension too stiff ! It is for carpet !
talking about carpet racing...y didnt you guys go to trt?? its like the only indoor track there....time for you guys to run those dusty ep of yours!!
hehehehe
disaster999 is offline
  #5043
Manticore's Avatar
Originally posted by Disaster999
how could an engine die on you?? just replace the sleeve and piston, bearings, shaft....and its good as new again!!
you better get a new engine if you are going to replace all those things you mentioned !!
Old 01-27-2002, 07:54 AM
  #5044
dtm
dtm's Avatar
you need to replace the connecting rod and waist pin to make the engine's life back.
I have the spares.... but the is very little compression from the piston! The present bushing in the con rod does not appear to be too worn.... only a slight 'shift' in the oil when you move it in the crank!! No mark on the wrist pin...last time I took it out...... about 2 gallons ago!!
dtm is offline
Old 01-27-2002, 07:55 AM
  #5045
Manticore's Avatar
hehehehe
we dont have good indoor carpet track for 1/12 ! TRT is just too small and the carpet is not the right material for 1/12
Old 01-27-2002, 07:56 AM
  #5046
dtm
dtm's Avatar
i know your comparing them...but im just wondering which one is from japan...
Manticore is right... everything is from Italy expect OS- Japan!!
dtm is offline
Old 01-27-2002, 07:57 AM
  #5047
dtm
dtm's Avatar
Good luck with your OS TR !
Thanks... I may need it!!!
dtm is offline
Old 01-27-2002, 07:58 AM
  #5048
Manticore's Avatar
the slop on the conrod enough to reduce the compression as the piston wont never go up to the right level. that's the reason you feel the compression fade out.
Old 01-27-2002, 07:59 AM
  #5049
dtm
dtm's Avatar
I thought you had another 5 port on order..... if not..... you can join the 'stupid' with a TR!!!!!
dtm is offline
  #5050
Regional Moderator
humm...finally something is better then japanese made! hehehehe.....
ya...i know the track there is small...but its not bad for people who got a bad itch and really want to play rc....hehehe
i think that track is more suitable for micro to play on!
you know what...i say team orion's micro motor for 450...its crazy!! even more then those 1/10 team motors!
Old 01-27-2002, 08:00 AM
  #5051
Manticore's Avatar
you need luck or OS TR ??
Old 01-27-2002, 08:01 AM
  #5052
dtm
dtm's Avatar
Certainly would be cheaper!!! $460 for piston n sleeve, $160 for con rod can't remember how much the wrist pin was!!!
dtm is offline
  #5053
Manticore's Avatar
yes, it is on order but not something i can get immediately
  #5054
Regional Moderator
ya...probally right...it might end up costing more than a new engine if your going to replace all those!!
Old 01-27-2002, 08:02 AM
  #5055
dtm
dtm's Avatar
BOTH....maybe!!!!!!!
dtm is offline
