HK Talk Version 1.1
Old 01-15-2002, 07:18 AM
  #4486
dtm
dtm's Avatar
Originally posted by Manticore
Check this out
Next Racing Developement
Hmm..... more toys to spend money on..... I wonder when they will start appearing in HKG??!!!! They look to be hand finished so price will be well into M Speed territory I expect!!
dtm is offline
Old 01-15-2002, 07:22 AM
  #4487
Manticore's Avatar
I never believe in this kind of mod and the only engine that give you consistant and gallons of run is standard engines. mod engines usually have low life span, fuel hungry and expensive.
Manticore is offline
Old 01-15-2002, 07:31 AM
  #4488
dtm
dtm's Avatar
True... but it is always fun to find out exactly how much you can squeeze out of the thing before it blows up on you!!!
The cyclinder looks really strange, the lites are far too small to be based on the NR cylinder! I saw a reference to Top CT12, but this is a side exhaust but they could be using the Top engine as a base instead!!!
Actually because the thing is obviously hand finished it would not be too difficult to spend a night creating a master piece of your own!!! I have learn a few good and bad things about changing the lites on these engines... it has been quite a 'costly' lesson at times!!!
dtm is offline
Old 01-15-2002, 07:35 AM
  #4489
dtm
dtm's Avatar
So why have you ordered a second modified RB 5 port!!!!!?????
dtm is offline
Old 01-15-2002, 07:36 AM
  #4490
Manticore's Avatar
but i am going to polish one of my engine crankshaft to see the effect. I used to do this to my 3.5cc engines years ago.
Old 01-15-2002, 07:37 AM
  #4491
Manticore's Avatar
because RB supplies the market with too little stock while the market has great demand on it and should reserve one before stock arrive.
Old 01-15-2002, 07:39 AM
  #4492
dtm
dtm's Avatar
First thing I normally do is to open the square inlet hole on the crank under the carb. I have found this has good effect on the pick up!! The original design creates a lot of turbulence.
dtm is offline
Old 01-15-2002, 07:40 AM
  #4493
dtm
dtm's Avatar
Are you trying to corner the market on RB engines???!!!
dtm is offline
Old 01-15-2002, 07:43 AM
  #4494
Manticore's Avatar
why should i do this stupid thing? I have a waigo sticker already !
Old 01-15-2002, 07:48 AM
  #4495
dtm
dtm's Avatar
So Waigo sticker on RB engine is the winning combination!!!!! It must be difficult getting the sticker NOT to melt!!!!
Mrs Chan must be very proud of you doing all this advertising for her!!!!
dtm is offline
Old 01-15-2002, 07:51 AM
  #4496
Manticore's Avatar
*BOW*BOW*BOW*
  #4497
dtm
dtm's Avatar
I installed the kawa straight shaft tonite. Found that the diameter of the shaft where the bearing sits was too large.... had to do a lot of work to get it to fit....... very disappointed with kawa I expect this from GPM!!!!! Maybe I should have bought that instead.... at least I would not have been surprised!!!
dtm is offline
Old 01-15-2002, 07:54 AM
  #4498
Manticore's Avatar
mind works great ! everything fit perfect. which car you put this thing on?
Old 01-15-2002, 07:58 AM
  #4499
dtm
dtm's Avatar
RR.... the shaft was so tight that you could not even hit the bearing in.... I had to resort to wet n dry paper!!!
dtm is offline
Old 01-15-2002, 08:03 AM
  #4500
dtm
dtm's Avatar
I also found the normal gear diff for the RR is 56g, the straight shaft is 37g!! Should help with the spin up time!
dtm is offline
