HK Talk Version 1.1
Old 01-05-2002, 09:35 PM
  #4066
ernestf's Avatar
Originally posted by dtm
Ernestf- Did you find out why your engine was so slow in the end?
yes, finally, i have lean the main needle 1 turn and tighten the 2speed screw 1/4 turn. it comes back .... but then, after a few more tanks, the front belt come off .....
ernestf is offline
Old 01-05-2002, 09:44 PM
  #4067
Manticore's Avatar
I like my MT12 very much too...... I was going to try out my old MT12 on the RR yesterday.......the one that went of a 3x,xxx rpm uncontolled spin.......to see if there was any life left in it! but it was already hectic trying out different settings on the RR without having to do an engine change as well!
you need a higher torque engine for foam tire setting. MT12 is good but not good enough when you compare to those 1.35HP engines
Manticore is offline
Old 01-05-2002, 09:45 PM
  #4068
Manticore's Avatar
Yes... once that second gear kicks in you can 'turbo boost' an EP a very very long way!!!!
missile is much faster then the fighter !
  #4069
ernestf's Avatar
u mean it is time to run in my NovaMega ???
ernestf is offline
Old 01-05-2002, 09:46 PM
  #4070
Manticore's Avatar
Originally posted by ernestf
dtm, i have to do something on my mtx2 to keep it perform and run with you guys, right now i am a few laps behind u and manticore
yeah you need to tune up !! you have all the goodies but you didnt put them on !
  #4071
ernestf's Avatar
i dont have much chance to "clean up" those EP road block. all the GP in front of me do the jobs pretty good ....
ernestf is offline
Old 01-05-2002, 09:47 PM
  #4072
Manticore's Avatar
why not? i dont want to keep new in box 1.35HP engine while there are 1.5HP engines available !!
  #4073
ernestf's Avatar
cuz i am slow in driving and building / re-building.
ernestf is offline
Old 01-05-2002, 09:49 PM
  #4074
dtm
dtm's Avatar
It's a big job to change that front belt... did it break or just come off. I remember when I was running the kawa alloy pullies on the MTX, after these wear they would tear up front belt! I got through 2 belts in 2 days before I threw the front alloy pulley away!!
dtm is offline
Old 01-05-2002, 09:51 PM
  #4075
dtm
dtm's Avatar
Thats exactly whats happening to me
dtm is offline
Old 01-05-2002, 09:52 PM
  #4076
ernestf's Avatar
it just come off, not broke, but anyway, i think it is time to replace new belts for the car. i am still using the stock front diff, but use the small pully from kawahara. i will install the front belt tensioner next time !
ernestf is offline
Old 01-05-2002, 09:53 PM
  #4077
dtm
dtm's Avatar
Front belt tensioner?? does that exsist??
dtm is offline
Old 01-05-2002, 09:55 PM
  #4078
ernestf's Avatar
yes, it is from kawahara
ernestf is offline
Old 01-05-2002, 09:56 PM
  #4079
Manticore's Avatar
i.e. alloy pulley no good no good !
Old 01-05-2002, 09:57 PM
  #4080
Manticore's Avatar
put up more stickers !!
