HK Talk Version 1.1
Old 01-04-2002, 10:42 AM
  #4006
Manticore's Avatar
Originally posted by dtm
hmm... that could be a problem!!! you wouldn't happen to know if the Koysho metal pinion housing can fit a Mugen clutch? Thks. I don't have a spare Mugen pinion housing and those Mugen gears are going to be a b!tch to get off!!
what i mean is to use kyosho clutch pinion and put it on mugen clutch bell !
Manticore is offline
Old 01-04-2002, 03:34 PM
  #4007
Yokomo Fan's Avatar
WHOA, nice shell Manti.
Yokomo Fan is offline
Old 01-04-2002, 04:45 PM
  #4008
Manticore's Avatar
*BOW*BOW*
Old 01-04-2002, 05:54 PM
  #4009
Diva's Avatar
Trader Rating: 14 (100%+)
Originally posted by Manticore
just use a mugen pinion removal tool ! thats why I only keep mugen centex !
Ohhhhh. I see why you always compliment the Mugen stuffs.
Diva is offline
Old 01-04-2002, 06:00 PM
  #4010
Manticore's Avatar
when when?
Old 01-04-2002, 06:01 PM
  #4011
dtm
dtm's Avatar
Should I get 999's pink rims?
hahaha..... I think the pink rims would look very nice on the shell!!!
dtm is offline
Old 01-04-2002, 06:03 PM
  #4012
dtm
dtm's Avatar
part number
B0513 Pinion Gear Tool
I remember seeing this......... but its probably all gone now!
dtm is offline
Old 01-04-2002, 06:04 PM
  #4013
Manticore's Avatar
did you check with cityhobby?
Old 01-04-2002, 06:06 PM
  #4014
dtm
dtm's Avatar
No, not yet..... I was still running EP when I saw the tool! I haven't thought about getting one until recently.... my mugen gears are starting to look a little worn!
dtm is offline
Old 01-04-2002, 06:10 PM
  #4015
Diva's Avatar
Just happened to see uncle Chan has a set of Kawa rear suspension systems with arms, elongated dogbone head, and most important the thinkened hex adaptor. This should be a proper way of using wide foam tyre instead of cutting the rear hub.
ernestf: will you consider to get one. It's $4xx
Diva is offline
Old 01-04-2002, 06:12 PM
  #4016
dtm
dtm's Avatar
$4xx will get you a lot of foam tires!!!!
dtm is offline
Old 01-04-2002, 06:15 PM
  #4017
dtm
dtm's Avatar
Originally posted by KY9fat
dtm - I thought Mr. CCC have got one of those?
He has the Serpent plastic one. OK for the original clutch but theres nothing to hold onto on the Centax clutch so not very good!!!
dtm is offline
Old 01-04-2002, 06:25 PM
  #4018
Regional Moderator
disaster999's Avatar
hahahaha...sure...y not??
disaster999 is offline
Old 01-04-2002, 06:43 PM
  #4019
Manticore's Avatar
you can see this at the track today !
Old 01-04-2002, 06:52 PM
  #4020
Manticore's Avatar
I think cityhobby still have that instock.
