HK Talk Version 1.1
Old 01-01-2002, 08:18 AM
  #3811
dtm
dtm's Avatar
Originally posted by Manticore
well, you can try the $40 one ! the braking disc shown on the pic is of very high quality! even better then the kawahara disc.
When i replaced the stock disc last night, I found that the adaptor holes on the stock disc has already been elonged badly even I havent applied much brake before.
I'll bear that in mind. The disc is one of the things I haven't replaced to the RR. Same as you... figured I won't be using it much!!
dtm is offline
Old 01-01-2002, 08:20 AM
  #3812
dtm
dtm's Avatar
Originally posted by ernestf
I hope I did buy my Pro3 from CC. It seems that the Pro3 that I bought from uncle Chan cannot perform as good as the one from CC.
Or, I have to switch from Pro2 to Pro3 in order to achieve this "GOOD" result ? anyone can help ?
No.. you first have to buy a Pro 2 to feel the improvement!!
dtm is offline
Old 01-01-2002, 08:21 AM
  #3813
dtm
dtm's Avatar
Originally posted by Disaster999
quote from RCCA..."but the dyno shows a staggering jump in power from 196 watts to 230.2 watts. For you math-impaired folks, thatís a 34.2W jump, or a 16.5 percent increase in power. There were also gains in torque and efficiency; the big brushes work. "
Do you know what turn motor they tested?
dtm is offline
Old 01-01-2002, 08:23 AM
  #3814
dtm
dtm's Avatar
Also I have strip the rear gearbox twice already! once for the lighten shaft and the second time for the alloy brake pulley........ I don't want to do it for the third time!!!!!
dtm is offline
Old 01-01-2002, 08:25 AM
  #3815
dtm
dtm's Avatar
I have sprayed up my RR shell. The car will be ready for Saturday!!!
dtm is offline
Old 01-01-2002, 08:27 AM
  #3816
Regional Moderator
disaster999's Avatar
its a speed gem 9x2
disaster999 is offline
Old 01-01-2002, 08:28 AM
  #3817
Manticore's Avatar
Thumbs down
dont ever trust those test by RCCA !! they are just advertising !
Manticore is offline
Old 01-01-2002, 08:29 AM
  #3818
Manticore's Avatar
I think you still havent run your RR yet???
Old 01-01-2002, 08:30 AM
  #3819
dtm
dtm's Avatar
ernestf/dtm/diva
check this out, the original kyosho option braking disc.
the kawahara oversize cooling head.
dtm: i wish it has the blue color !!
I've got the head from Uncle Chan very cheap.
Manitore- is that your car in te pic?..... you finually found the K&N filter!!!
dtm is offline
Old 01-01-2002, 08:31 AM
  #3820
Manticore's Avatar
the kyosho VSD body is available seperately but I think this body is ultra thin and not good for bashing !!
Frewer is still the way to go !!
  #3821
dtm
dtm's Avatar
Thats right!!!! Thats why I don't want to do another gearbox strip!!!
dtm is offline
Old 01-01-2002, 08:33 AM
  #3822
dtm
dtm's Avatar
It appears to be the thinnest of the lot. But in terms of mould quality it is the best....... just don't hit me on the side!!!
dtm is offline
Old 01-01-2002, 08:36 AM
  #3823
Manticore's Avatar
My friend in the states sent this to me !
Old 01-01-2002, 08:37 AM
  #3824
Manticore's Avatar
I will only kick your butt ! dont worry !
Old 01-01-2002, 08:40 AM
  #3825
Mars's Avatar
Originally posted by MIKA
Mars: Thanks for your concern. My car has poor acceleration and under-steer in tight corners and that is where I've lost a lot of time. No doubt that the SP is a very stable car but refuse to attack tight corners. I've tried the 3deg. caster but it created new problems at high speed corners.
We normally race on a tight & medium grip carpark. Andy Lam previously told me to "pull and lift the rear gearbox forward" with the long upper tie-rod, but I still try to figure how to do it. Others also told me that I've to do modification to the rear gearbox to improve stability in tight corners? I was also told that the SP MUST use the team Suzuzi 'white' front one-way and ball diff pulley with the new belts to improve acceleration and efficiency??
I think the tricks people mentioned about the drivetrain of MR4TCsp are not must haves. Actually the stock parts included in the sp kit are fine stuff, including the diff pulleys. are you using shims to take up all the play? too much shims can bind the rotating parts. I run a pretty normal Masami setup, with some modifications in shock length and camber angle. The car always perform to my satisfaction. Hope you won't abandon the car too soon. It can be improved
Mars is offline
