HK Talk Version 1.1
Old 01-01-2002, 12:33 AM
  #3796
dtm
dtm's Avatar
oops...duplicate post!
dtm is offline
Old 01-01-2002, 03:31 AM
  #3797
Mars: Thanks for your concern. My car has poor acceleration and under-steer in tight corners and that is where I've lost a lot of time. No doubt that the SP is a very stable car but refuse to attack tight corners. I've tried the 3deg. caster but it created new problems at high speed corners.
We normally race on a tight & medium grip carpark. Andy Lam previously told me to "pull and lift the rear gearbox forward" with the long upper tie-rod, but I still try to figure how to do it. Others also told me that I've to do modification to the rear gearbox to improve stability in tight corners? I was also told that the SP MUST use the team Suzuzi 'white' front one-way and ball diff pulley with the new belts to improve acceleration and efficiency??
MIKA is offline
Old 01-01-2002, 03:35 AM
  #3798
Regional Moderator
disaster999's Avatar
Originally posted by dtm
you will be needing the assistance of our "forklift" capabilities when you turn over!!!!!!
heyhey...whats your number....i think ill be needing that service quite often!!
hahahaha
disaster999 is offline
Old 01-01-2002, 03:36 AM
  #3799
Regional Moderator
Originally posted by KY9fat
Just got back golfing in mainland, what have you got me this time?
mission hill?
Old 01-01-2002, 03:55 AM
  #3800
Originally posted by ernestf
This is the first funny thing I see on 2002 :
"ive just got the Pro3 Hong Kong edition from Control Centre, and the car handles near perfect out of the box. I race on carpet, and found alot more speed than my Pro2, i dont think the slight flex (using graphite chassis but no upper deck) is that much of a deal. It won me the race yesterday, so i cant really expect more.
When i say out of the box, i dont mean springs and gears though."
It is quoted from pro3 forum.
Because it is from CC.
Tsubasa Sakai is offline
Old 01-01-2002, 03:57 AM
  #3801
dtm: But you don't include the shim between the engine and flywheel wow.
Old 01-01-2002, 05:53 AM
  #3802
Regional Moderator
heyhye...anyone know if the P-94 style big brush conversion kit had arrived in HK yet? after reading the article on it...it increased the overall performance of the motor...and i want to try it!
Old 01-01-2002, 07:15 AM
  #3803
dtm
dtm's Avatar
oops...sorry. I must have left it on the engine! Do you have any clearance between back of flywheel and front of engine now?
dtm is offline
Old 01-01-2002, 07:16 AM
  #3804
dtm
dtm's Avatar
Tell me what your results are?
dtm is offline
Old 01-01-2002, 07:54 AM
  #3805
ernestf's Avatar
comment from rc car action ???? i dont really believe if Trinity can make good motor
ernestf is offline
  #3806
Manticore's Avatar
I thought about (and may still) getting this head. It's not the 'right' colour but I still think better than purple!
The brake disc looks a lot like the one that International is selling for $40!!!!
well, you can try the $40 one ! the braking disc shown on the pic is of very high quality! even better then the kawahara disc.
When i replaced the stock disc last night, I found that the adaptor holes on the stock disc has already been elonged badly even I havent applied much brake before.
Manticore is offline
Old 01-01-2002, 07:56 AM
  #3807
ernestf's Avatar
Originally posted by Manticore
ernestf/dtm/diva
check this out, the original kyosho option braking disc.
the kawahara oversize cooling head.
dtm: i wish it has the blue color !!
I've got the head from Uncle Chan very cheap.
Really want to see the real thing running on the track.
ernestf is offline
Old 01-01-2002, 08:06 AM
  #3808
ernestf's Avatar
I hope I did buy my Pro3 from CC. It seems that the Pro3 that I bought from uncle Chan cannot perform as good as the one from CC.
Or, I have to switch from Pro2 to Pro3 in order to achieve this "GOOD" result ? anyone can help ?
ernestf is offline
Old 01-01-2002, 08:17 AM
  #3809
Regional Moderator
quote from RCCA..."but the dyno shows a staggering jump in power from 196 watts to 230.2 watts. For you math-impaired folks, thatís a 34.2W jump, or a 16.5 percent increase in power. There were also gains in torque and efficiency; the big brushes work. "
Old 01-01-2002, 08:18 AM
  #3810
Manticore's Avatar
I think the RC car manufactorer soon will be bundling WC fingers with their cars !
