HK Talk Version 1.1
Old 12-18-2001, 10:11 AM
  #3136
dtm
dtm's Avatar
It makes the Mad Bison look like a TC!! That fuel tank looks BIG.
dtm is offline
Old 12-18-2001, 10:13 AM
  #3137
Regional Moderator
disaster999's Avatar
looks just like T-MAXX!!
disaster999 is offline
  #3138
dtm
dtm's Avatar
Originally posted by ernestf
the new kx1 layout is : it has normal lower graphite plate as typical graphite board chassis. the plate is balance in left and right side, with 2 rows of 4 long batt slots (long = longer than a batt needs) parallel to the chassis. those jap racers place lead weight and electronics gear on the right side of the chassis, and use the rest batt slot for the batt placement.
kyosho just release some new graphite composite parts for the KX1, which is also included in the prototype car.
Will you upgrade your KX-1 ernestf?
dtm is offline
Old 12-18-2001, 10:14 AM
  #3139
M 5
Here's my monster blazer
M 5 is offline
Old 12-18-2001, 10:15 AM
  #3140
M 5
Yea, its a good comparison.
The fuel tank is 150cc.
M 5 is offline
Old 12-18-2001, 07:39 PM
  #3141
Diva's Avatar
Trader Rating: 14 (100%+)
It seems that you're a GPM fan. Boy
Diva is offline
Old 12-18-2001, 07:57 PM
  #3142
fai
Regional Moderator
fai's Avatar
OG, the Tech TC3 front oneway is available again just got one.
I saw a new KX1 in ontau shop today, it was the one that used by those Kyosho team driver in the last race. it carry some new Kyosho graphite composite parts (use to be pure plastic), and a new hand-made bottom plate to hole the batt, it is just a prototype.
Ernestf: you're right, those Kyosho team Kx-ones no more have the battery in the centre, but with a 3 x 2 front to rear arrangment. But really don't know how can they 'stick' the lower graphite chasis back on to the 'main bones'...
fai is offline
Old 12-18-2001, 08:02 PM
  #3143
fai
Regional Moderator
fai's Avatar
Originally posted by over gear
wow... what's stock in Hara's car beside a-arms and ball cups?
how did Barry Baker do?
OG: oh... Hara ran nearly stock with his pro3, except using a HB upper deck (he's not using the one with 'side battery')!!
I also found that he cut the HB upper deck in order to gain more flex...
fai is offline
Old 12-18-2001, 08:50 PM
  #3144
over gear's Avatar
Trader Rating: 17 (100%+)
Thumbs up
ernestf: how much is the oneway?
over gear is offline
Old 12-19-2001, 02:01 AM
  #3145
fai
Regional Moderator
fai's Avatar
Here is the final qualify result of last Sunday HK International race:
fai is offline
Old 12-19-2001, 02:02 AM
  #3146
fai
Regional Moderator
fai's Avatar
Here is Surikarn's winning 414M:
fai is offline
Old 12-19-2001, 02:11 AM
  #3147
fai
Regional Moderator
fai's Avatar
Here is the track layout:
fai is offline
Old 12-19-2001, 02:14 AM
  #3148
fai
Regional Moderator
fai's Avatar
Attached pic. was taken 2 minutes before Hara's 1st final. He was peaking battery at that moment...
fai is offline
Old 12-19-2001, 02:19 AM
  #3149
fai
Regional Moderator
fai's Avatar
This photo was taken 1 minute before 1st final... Hara was adjusting his rear wing in a hurry and Umino was helping out to put collars at the rear posts of Hara's pro3.
fai is offline
Old 12-19-2001, 04:55 AM
  #3150
dtm
dtm's Avatar
I like that.... Hara and Umino are wrapped up like eskimos and theres a guy in the background in a TC3 Tee shirt!!!
dtm is offline
