HK Talk Version 1.1
Old 12-16-2001, 06:26 PM
  #3031
Mars's Avatar
999: Masami didn't come.
dtm: I was in C-main. Finish at 6th or 7th. Didn't really check the position
Mars is offline
Old 12-16-2001, 07:10 PM
  #3032
dtm
dtm's Avatar
congratulations! Not bad with so much competition!
dtm is offline
Old 12-16-2001, 07:17 PM
  #3033
dtm
dtm's Avatar
Originally posted by Ah10
Manticore told me Mid oneway will and can improve off steering! I might be wrong! But anyway it is a good think to have that's why I asked you to get one for me!
I can only go by my EP experience here! In theory if you let go of the throttle with no mid one-way you have the friction of all 3 belts 'braking' the rear wheel, this may loosen your rear end more.
If you have mid one-way, the friction of only 2 belts will be 'dragging' the rear wheel. This means more stable rear end and carry more speed around corners.
With EP, running only front one-way can result in the rear end breaking loose when you let go of the throttle, It is slightly different for GP because you do not really get motor braking from your engine! Confused...... I think I am now!
dtm is offline
Old 12-16-2001, 07:34 PM
  #3034
ernestf's Avatar
mars, thx for the updates.
so tamiya ruled the race on sunday
it is time for me to build my tamiya kits then .....
ernestf is offline
Old 12-16-2001, 07:44 PM
  #3035
Diva's Avatar
Trader Rating: 14 (100%+)
Originally posted by dtm
Manticore- GP was real fun yesterday! I'd forgotten how crazy these things accelerate... wiped out a rear hub before I finished my first tank! Its a good thing I went to PYC and not EGR to test the car..... otherwise I would have been picking up the pieces today!! Thanks for the advice on the centre one-way..... my MTX was running like an EP!!
It was my first time running MTX. Not until then did I realise that its handling is soooo good. I was running 4WD with slick tyres. The cornering was terrific. Now I know why many ppl own both V1 and MTX. They are totally different in handling characteristics.
Ah, one more thing to mention. The JPL pipe (from Taiwan) is very good.
Diva is offline
Old 12-16-2001, 07:58 PM
  #3036
Diva's Avatar
Any body knows how big (in uf) should I put on the capacitor for 8T or lower motor? My steering servo glitched on throttle.
Diva is offline
Old 12-16-2001, 08:00 PM
  #3037
Mars's Avatar
dtm: my target was b-main. couldn't make it. really difficult to find right setup and tire/insert mix for such bumpy and dusty condition.
ernestf: you should have done that long time ago
Mars is offline
Old 12-16-2001, 08:13 PM
  #3038
dtm
dtm's Avatar
Welcome to the club!!
dtm is offline
Old 12-16-2001, 09:34 PM
  #3039
Did Hara visit Hk's local track EGR?
rcethilon is offline
Old 12-17-2001, 02:19 AM
  #3040
fai
Regional Moderator
fai's Avatar
Dear Diva, I tried something like 1600uf to the receiver and it doesn't help too much... Finally I replaced my FET servo to a non-FET one and it seems to be better!!!
fai is offline
Old 12-17-2001, 02:21 AM
  #3041
fai
Regional Moderator
fai's Avatar
Mars: If you were not blocked at the final qualify, I think you should have no problem gotting into B-main... Don't be too unhappy lar!!!
fai is offline
Old 12-17-2001, 02:28 AM
  #3042
Mars's Avatar
Fai: I am not unhappy, it's just regretable to miss a chance of doing better in such big race. I'll keep trying next year!
Mars is offline
Old 12-17-2001, 02:46 AM
  #3043
fai
Regional Moderator
fai's Avatar
Friends: Wow, just had a fun day yesterday... at the HK big race!!! Spent a whole day going around the pits and used my camera "snap snap" all those pro-racers and pro-cars!!
For me, I think the most innovative pics. are the 'side battery' pro3!! Yes, the battery is placed on one side and all electronics on the other side! It was tested by Hara on the first day but was put away finally...
Champion Surikarn really dominated the race with his 414M... He's the fastest around the corners... But still really don't know what tire insert was he using???
Hara's pro3 is a little bit 'freezed' when entering corners... He said that this time he was sponsored by HPI, so only the upper deck is from HB, all other parts are from HPI!!
fai is offline
Old 12-17-2001, 02:48 AM
  #3044
fai
Regional Moderator
fai's Avatar
Mars: yeah right!
fai is offline
Old 12-17-2001, 03:00 AM
  #3045
ernestf's Avatar
Fai, did Hara mean that HB optional parts for Pro3 is way better than those from HPI ?? haha
Do u have any photo that can be shared with us ???
ernestf is offline
