HK Talk Version 1.1
#2791
Mars: your PM box is full ar... haha.... i cant sent you message....
#2792
#2793
Originally posted by Disaster999
cool....guess ill try it then....considering that it is cheaper then rubber tires....140 for 2 pair!
but it wears out pretty fast ya?
#2794
Manticore: what should i get along with the kit? i am thinking 7075 chassis, graphite upper deck, the layshaft mount in the front, Kawahara negative diff. btw the way, do you know who distribute kawahara stuff in HK?
and what about engine? i am thinking between a RB turbo 5port and a Collari 12RT 5 port... they are not the same thing, right?
dtm: are you going to the international race this weekend?
#2795
The RB 5 port should give you good enough power. Never seen people use Collari .12 engines here. May be I have been stayed away from GP over a month.
#2796
Manticore: you have EP? are those K-factory stuff good? you mean the LCG fuel tank? you think it helps? i thought the Kawahara diff is cheaper than the Kyosho one...
#2797
#2798
Originally posted by Manticore
Yeah get the kyosho original option 7075 chassis. kawahara upper deck is nice but you cannot install the k factory fuel tank with it. I am using square upper deck and quite happy with it. metal mid shaft holder, metal upper deck support. metal disc brake adaptor, rear graphite shock tower, I would say the kyosho LSD on the rear is good enough.
#2799
Originally posted by dtm
No centre one-way?
No centre one-way?
Are you able to get hold one of those TECH mid one-way for your MTX2?
#2800
I went to MK today and left with a new RR.......... anyone want an 'almost new' stock VoneR? I will transfer the chassis plate from the RR onto it!
#2801
sure, i missed that out!
PG has one more Tech centre one-way left!
#2802
#2803
Both the chassis plates are exactly the same!
#2804
The Kyosho VDS shell is extremely thin. The sides are like 'paper' thin... not very good! But at least all the cutout marks should fit the chassis nicely!
#2805
