HK Talk Version 1.1
Old 12-09-2001, 03:04 AM
  #2776
Regional Moderator
Default Re: Tekin 112a
Originally posted by kayun007
anyone had used or using the Tekin 112a??
can the software version H27 charge the 3000 batt.??
Yes, it can charge 3000 batt. P1 is the only mode you can use for Nimh. P2 and CS will damage them.
White cat is offline
Old 12-09-2001, 03:29 AM
  #2777
PeterCheung's Avatar
Default Re: Re: Tekin 112a
white cat, u have the 112a??
do u think it is a good charger??
PeterCheung is offline
Old 12-09-2001, 06:42 AM
  #2778
ernestf's Avatar
me-student : welcome back. come back so freq !!
hope we can meet on track again and run. have u brough your radio gears with u this time ?
ernestf is online now
Old 12-09-2001, 07:32 AM
  #2779
dtm
dtm's Avatar
Originally posted by ME-student
DTM: lots of stuff that i want to get. i am thinking at least a V1RR and a TB EVO2... or maybe more...perhaps TXT-1..... kakaka
Manticore: i dont think i will fire up my car in HK... just want to learn more stuff from you guys.... this is my first GP..
You're cetainly not messing around with RTR stuff. First GP an RR with Collari engine.... wow!
dtm is offline
Old 12-09-2001, 07:35 AM
  #2780
dtm
dtm's Avatar
P0 is safer! but you may get some false peaks with older packs. I don't know if H27 had P0 but H30 certainly did!
dtm is offline
Old 12-09-2001, 07:38 AM
  #2781
dtm
dtm's Avatar
Originally posted by Disaster999
i always wanted to try using foam on eletric....
how did it go?
The car corners like a train on rails! but very wastful on the batteries because you can't fully let go of the throttle out of the bends! Takes a little getting use to but more power equals more steering!! you have to be brave in mid-corner and stab that throttle!!!
dtm is offline
Old 12-09-2001, 07:50 AM
  #2782
dtm
dtm's Avatar
One other thing... you HAVE to swap tires left and right after each pack. I got lazy and didn't do it for the last 3 packs. The left front tire is now 3mm larger than the RH tire!
dtm is offline
Old 12-09-2001, 07:52 AM
  #2783
dtm
dtm's Avatar
BTW. PYC has changed it's track, it's much more boring for EP now. If you get a chance, run reverse track it is much much more fun for EP! Just be careful of the hairpin in front of the drivers stand!!!!
dtm is offline
Old 12-09-2001, 07:54 AM
  #2784
Regional Moderator
disaster999's Avatar
sounds like lots of fun!!
ill try that with my brothers yokomo foam!! hahaha...
what? 3mm bigger then the RH ones? how could that be? i mean...theres LEFT turns and RIGHT turns....y could one side be smaller?
disaster999 is offline
Old 12-09-2001, 08:00 AM
  #2785
dtm
dtm's Avatar
PYC is always basis to one side. Because we were running reverse track the right tire worn out quicker than the left!
dtm is offline
Old 12-09-2001, 08:07 AM
  #2786
ernestf: i didnt bring them back. but Mars will help me out on that if i want to run. how you doing with your pro3? hope those new options on the V spec car arrive soon.
dtm: hehe, i need to get the best stuff to balance with my poor skill...! i will get the Collari 12RT 5 port, i think the advertise HP is 1.39... or more..
ME-student is offline
Old 12-09-2001, 09:10 AM
  #2787
Regional Moderator
cool....guess ill try it then....considering that it is cheaper then rubber tires....140 for 2 pair!
but it wears out pretty fast ya?
Old 12-09-2001, 05:41 PM
  #2788
Regional Moderator
Default Re: Re: Re: Tekin 112a
It is a reliable charger but it doesn't have enough functions.
Old 12-09-2001, 05:42 PM
  #2789
Regional Moderator
H27 has no P0.
Old 12-09-2001, 05:54 PM
  #2790
Mars's Avatar
got some nice price present from USA?
Mars is offline
