HK Talk Version 1.1
Old 12-07-2001, 10:32 PM
  #2746
dtm
dtm's Avatar
Originally posted by ernestf
dtm, is your GP ready yet ?
Almost! Will be ready next week!
dtm is offline
Old 12-07-2001, 10:36 PM
  #2747
dtm
dtm's Avatar
I have found something to keep me interested in EP for a little longer....... foam tires!!!!!!! If you want to drive a train..... go for foam!!!
dtm is offline
Old 12-07-2001, 10:48 PM
  #2748
Any of you guys on here own or have had any experience with a Alex Racing Design CE4?
I am having problems with the rear delrin diff. I can't seem to get smooth free spinning diff action. If I set it loose enough where it feels good the pulley just slips and when I tighten it to the point where it is difficult for the pulley to slip the diff action is tight as hell! I have taken it apart and assembled it three times, I haven't got a clue what the problem is. I have assembled delrin diffs on an OB4 and they spun very free but did not slip. I have never had this problem before and I know it is assembled correctly. Any help is appreciated.
WailinOnYa is offline
Old 12-08-2001, 04:02 AM
  #2749
Manticore's Avatar
glue the diff ring onto the outdrive with the "all purpose" adhesive (not CA). only adjust the diff after the adhesive sit overnight.
Manticore is offline
Old 12-08-2001, 08:27 AM
  #2750
dtm
dtm's Avatar
Why not use CA?
dtm is offline
Old 12-08-2001, 08:38 AM
  #2751
Manticore's Avatar
Originally posted by dtm
Why not use CA?
CA doesnt hold as good as "general purpose" adhesive. Besides, CA dries too fast and leave an uneven layer between diff ring and outdrive.
Old 12-08-2001, 08:43 AM
  #2752
dtm
dtm's Avatar
I use to use CA by putting the ring on and "seeping" the CA between the ring and outdrive. It doesn't stick as well but I liked it because I could "break" off the ring and then scrap the CA off the outdrive... because it didn't stick as well!
dtm is offline
Old 12-08-2001, 08:45 AM
  #2753
dtm
dtm's Avatar
Actually- Fender Mender would probably be a good material too because you can "peel" this off the outdrive! Haven't had a derlin outdrive for a long time since the first batch of TC3....... when I went to GPM!!!
dtm is offline
Old 12-08-2001, 09:14 AM
  #2754
ernestf's Avatar
dtm, u used to have TC3 as well ??
ernestf is offline
Old 12-08-2001, 09:18 AM
  #2755
dtm
dtm's Avatar
I still have!! It was a Christmas present..... cannot sell!!!
dtm is offline
Old 12-08-2001, 09:38 AM
  #2756
ernestf's Avatar
but u wont run it anymore, right ?
ernestf is offline
Old 12-08-2001, 09:47 AM
  #2757
dtm
dtm's Avatar
One day I will run it again. The problem is that the Q is too long before it gets to the TC3. I bought an original front one-way for it just before I put it into semi retirement, it hasn't been run in yet!
dtm is offline
Old 12-08-2001, 06:59 PM
  #2758
Manticore, DTM: i am here! haha.. in HK i mean. i am getting a v-one-rr, any suggestions? have you guys heard of collari engine? hopefully i'll be seeing everyone at PYC or EGR...
ME-student is offline
Old 12-08-2001, 07:01 PM
  #2759
dtm
dtm's Avatar
Ahh.........time to spend money!!! How long are you staying?
dtm is offline
Old 12-08-2001, 07:07 PM
  #2760
DTM: leaving on the 2nd. heard you are going back to GP, you need some new options?
