HK Talk Version 1.1
Old 11-20-2001, 12:43 AM
  #2281
Diva's Avatar
Trader Rating: 14 (100%+)
Bingo
Diva is offline
Old 11-20-2001, 12:48 AM
  #2282
ernestf's Avatar
diva, if you are going to buy a new EP chassis, which one u will take ??
ernestf is offline
Old 11-20-2001, 12:50 AM
  #2283
ernestf's Avatar
KY9fat, i miss my car too. havent visited the track for about a month already. but at least, i can see my cars when i back home
ernestf is offline
Old 11-20-2001, 12:58 AM
  #2284
dtm
dtm's Avatar
Originally posted by Diva
Perhaps your wife is racing with your XRay at PYC against Jong Sau Lo. You never knows...
she would probably be faster!!!!
dtm is offline
Old 11-20-2001, 12:59 AM
  #2285
dtm
dtm's Avatar
Originally posted by KY9fat
Reading this forum makes me cry..I miss my x-ray
Don't let my wife know. she kill me if i said i miss my cars more than her
I thought there was a declaration of war up there in Xmn!!!! How comes you still have time for internet!!!!
dtm is offline
Old 11-20-2001, 01:00 AM
  #2286
dtm
dtm's Avatar
Most EP cars don't have the upper mount for bumper as what most GP cars do. It induces great pressure to the plastic and the posts upon crashes. Anybody know how to modify? Don't give me the answer "Switch to XRay".
Mount the front body post from the front shock tower and not bumper!!!
dtm is offline
Old 11-20-2001, 01:03 AM
  #2287
dtm
dtm's Avatar
Another Xray!!! No, actually I'm taking quite a liking to the 414M! But I'm afraid there will be a new 414 just around the corner!
dtm is offline
Old 11-20-2001, 01:47 AM
  #2288
Diva's Avatar
Probably TA03
Diva is offline
Old 11-20-2001, 01:55 AM
  #2289
ernestf's Avatar
dtm, what make u interest in 414M ??? Because you got an attractive offer ???
ernestf is offline
Old 11-20-2001, 02:43 AM
  #2290
dtm: What are the necessary additional option parts which must come with the Xray kit. I was told that, i.e., front one-way, belt tensioner, a set of 4 orange spring. How much is the front one-way selling in Hong Kong? How reliable is the kit's center one-way & other parts? Shall I get the option center one-way as well? Does the car have good power consumption, i.e., longer run time compare to the Yok-SP.
I should have listen to uncle Chan for getting the Xray when I was in Hong Kong 2 months ago.
MIKA is offline
Old 11-20-2001, 02:56 AM
  #2291
KY9fat's Avatar
WAR is an understatement!
Ahhh my notebook just crashed and I can't re-boot it
KY9fat is offline
Old 11-20-2001, 02:58 AM
  #2292
KY9fat's Avatar
Probably TA03
I've got one of those too..somewhere....
KY9fat is offline
Old 11-20-2001, 03:00 AM
  #2293
KY9fat's Avatar
you might be right
KY9fat is offline
Old 11-20-2001, 03:24 AM
  #2294
dtm
dtm's Avatar
No that was just on a straight 414 not the 414M. Its just that I would really like a 'competative' Tamiya!!
dtm is offline
Old 11-20-2001, 03:34 AM
  #2295
dtm
dtm's Avatar
You only really need the front one-way and harder white springs. The car comes with the orange springs already but they are probably too soft. Some of the second batch cars had quality problems with the front belt which meant it required the front tensioner. Xray reckon they have sorted this. I have not had to run the tensioner on my first batch car. It is fairly easy to make a front tensioner yourself with a fixed servo horn anyway.
The front one-way sells for a list price of HK$234, 6mm with lighten spring steel cups! Its a work of art for the price!!
The optional centre one-way is more of a design improvement rather than an option. I would imagine that new kits will come with this anyway. The original problem is really easy to fix, the one-way bearing slips in the plastic pulley. Just take it apart and epoxy the two together... you no longer need the 'optional' part .
As for power consumption it is no better or worse than any of the other cars available.... much more dependent on your throttle finger. One thing is that the bearings that come with the car has grease which is too thick. You can either run the car for 30 packs or take the bearings out and soak in a bearing cleaner and use normal bearing oil. That will short cut the run-in process!!
dtm is offline
