HK Talk Version 1.1
Old 11-19-2001, 08:31 PM
  #2266
fai
Regional Moderator
fai's Avatar
Ernest: My new chasis is same as yours... tube chasis! Hara's one is not yet released to the market, but I think they are ready to do that before Christmas!!
In my opinion, I suggest always run with an upper deck... I think the elasticity of the tube chasis will be greatly reduced after running for a few times. So, if you then installed back the upper deck, the whole car will not be so 'rigid' as it should be...
fai is offline
Old 11-19-2001, 08:43 PM
  #2267
ernestf's Avatar
fai, will u consider the graphite shocks tower from HB ??
ernestf is offline
Old 11-19-2001, 09:06 PM
  #2268
fai
Regional Moderator
fai's Avatar
Ernest: I don't think so, if we use HB shock towers, we have to shorten the dampers to at least 60mm (original 64..65mm) or we have to swap to use yoko. dampers. Otherwise, the car will have too much downtravel.
I think I will wait for HPI or square's one...
fai is offline
Old 11-19-2001, 09:49 PM
  #2269
dtm
dtm's Avatar
Yes, someone else ran the HB shock towers without changing the damper length. Ended up with his drive shafts popping out of the diff all night!!
dtm is offline
Old 11-19-2001, 09:52 PM
  #2270
dtm
dtm's Avatar
DTM/Albert: Thanks for your free ride last Saturday! I've started moving all components of my pro3 to the new stiffen chasis... Hope I can finish it on time this week!!
By the way, last Saturday, I had a look at Uncle Chan's SpeedMind. I found that its front ride height is very low, approx. 3.5..4mm and the rear end is about 5mm. The dampers were working very fine, with the front spring a little bit sofer than the rear... I can feel all these with my hands...
I'm surprised that Uncle Chan still has new Daytonas for sale in his shop. I thought they were limited editions to very small numbers! The car does look quite good though!
dtm is offline
Old 11-19-2001, 09:53 PM
  #2271
dtm
dtm's Avatar
Fai- I think Uncle Chans Daytona is running Atlas shocks...... these units will fit you're Pro 3 too!!! I've tried!!!...... something else to buy!?!
dtm is offline
Old 11-19-2001, 09:57 PM
  #2272
fai
Regional Moderator
fai's Avatar
DTM: yeah, you're right! I also knew that he had put 2 and a half o-rings over the diaphragm!
So, how can I get 2 pairs of brand new Atlas dampers??
fai is offline
Old 11-19-2001, 10:05 PM
  #2273
dtm
dtm's Avatar
You're getting hooked on this o-ring thing!!!
How did he get the half o-ring in???
You can try JET to see if they still have the Atlas dampers!!
dtm is offline
Old 11-19-2001, 10:23 PM
  #2274
ernestf's Avatar
Atlas has two different version of damper as far as I know. One type is the set come with the old YM34 which is longer, another type is the set come with the Type T which is a lot shorter !
ernestf is offline
Old 11-19-2001, 11:41 PM
  #2275
KY9fat's Avatar
Reading this forum makes me cry..I miss my x-ray
Don't let my wife know. she kill me if i said i miss my cars more than her
KY9fat is offline
Old 11-19-2001, 11:44 PM
  #2276
KY9fat's Avatar
Originally posted by Diva
Since I was afraid of receiving ticket again, I just rushed into Kin Chuen and got an Atlas 10T Dbl in 20s (at 9.9s/100m). What a horrible shopping experience
diva, where's your BL motor?
KY9fat is offline
Old 11-19-2001, 11:55 PM
  #2277
Diva's Avatar
Trader Rating: 14 (100%+)
100% money back gaurantee! GBP252 was deposited to my bank a/c.
Diva is offline
Old 11-20-2001, 12:01 AM
  #2278
Diva's Avatar
Most EP cars don't have the upper mount for bumper as what most GP cars do. It induces great pressure to the plastic and the posts upon crashes. Anybody know how to modify? Don't give me the answer "Switch to XRay".
Diva is offline
Old 11-20-2001, 12:09 AM
  #2279
Diva's Avatar
Perhaps your wife is racing with your XRay at PYC against Jong Sau Lo. You never knows...
Diva is offline
Old 11-20-2001, 12:17 AM
  #2280
ernestf's Avatar
Diva : here is my suggestion -
modify your hand ! DON'T CRASH ANYMORE !
J/K
ernestf is offline
