HK Talk Version 1.1
#211
Originally posted by dtm
Netvigator broadband use to be OK. But for last six months the connections has been slow. Now I find that it simply locks up sometimes and I have to log out and reconnect for a faster connection. It is getting to be a bit of a pain. But I think the speed of the connection is based on how many other users are also logged on in your area. I guess there are too many people using the service around me!?!
#212
KY9 and another friend zapped some old Sanyo 3000s.... they've been telling me that they can only charge to 2500mah now...... beware! I zapped a pack of 2400s which were very soft to start off with. After a couple of charges of increased voltage the cells became VERY dead! They are in the bin now!
#213
Regional Moderator
DTM: I see. I also think of the risk of zapping Sanyo 3000 so I did to only one pack for a trial!!
Jeff: By the way, zapping the batt. is nothing specail... Just lanch a cell and press a button! Don't expect sparks coming out and chemical leaking!!! Nothing happened. I nearly forgot which cell is zapped and which is not!
Mars: You'll race YMC this Sunday?? Good Luck!
#214
Regional Moderator
Manticore: Yeah, so I put approx. 40V to each cell according to Ernest's suggestion... You know, my 3000 batt. are really old...
#216
fai: yes, I joined the race
guys, seems that the new Sanyo3000HV will be available next month.
#218
ah wai, sorry i have overlooked your message.
i am running a LRP Quantum Sport (less then $480) on my RS4 Micro. So far I only see two hopups available in HK : front univ shafts (around $200) and front one-way (around $200). I have them already. But I think I still need the rear ball diff and high grip tires. They are not available yet.
#219
#220
Originally posted by ernestf
manticore, sure, u can use it too. but make sure you use 90V to deal with your batt
#221
Originally posted by Manticore
you cant zapp old cells with too high voltage.
On my 2400 I used MAX volts.... just to see.... I was going to throw the pack away anyway!
#222
#224
every car has side batt now
#225
dtm: that's how the rc companies survive
