HK Talk Version 1.1
Old 11-15-2001, 08:27 AM
  #2191
ernestf's Avatar
fai, dtm, i just re-setup my YM34 (which sleep for a yr already) and will be back to RC next week. still have some family issue to deal with.
hope u guys have fun on Sat !
ernestf is offline
Old 11-15-2001, 08:29 AM
  #2192
ernestf's Avatar
just find out one thing : MR4TC share the same position of rear body post holes YM34 !
my old MR4TC body is now on my YM34 !
ernestf is offline
Old 11-15-2001, 09:10 AM
  #2193
Regional Moderator
disaster999's Avatar
Originally posted by Diva
Still resting on my garage. I visited EGR most of the time. But it seems that EP is going to heat again. Many good cars have been launched. Perhaps I might get a Type-T or X-Ray.
Any you? TC3?
so...do you regret selling your cars?? hehehe!! or you didnt sell any? cuz last time i meet you you said that you want to play GP and giving up on EP!
disaster999 is offline
Old 11-15-2001, 09:11 AM
  #2194
Regional Moderator
Originally posted by ernestf
diva, i gave up my TC3.
i digged out my old chassis and rebuilt the old YM34. i will run this car until i finish with the new cars.
i havent been to EGR for GP for almost a month. i spent more time in EP lately.
hahha...i gave up TC3 a long time ago la!!
Old 11-15-2001, 09:13 AM
  #2195
Regional Moderator
Originally posted by dtm
Look at the colour of the brush after a full speed run. If only just the very tip has just started to discolour then its is about right! Lots of burnt marks.... drop a tooth on the pinion. No burnt marks....... go up a tooth on the pinion!!
hey...nice tip...thanks!
Old 11-15-2001, 09:16 AM
  #2196
Regional Moderator
Originally posted by Manticore
some information want to share with you about gearing.
first you need to understand the torque output of electric motor. the theory is that at zero RPM the motor generates greatest torque while at high rpm it has less torque.
i.e. you can actually over gear a motor but be sure you dont use full throttle at the straight to avoid extreme power comsumption. the brushes problem that you have is actually caused by loading the motor at high RPM at most of the time. i.e. high rpm = higher friction between brushes and com = high temp at com area.
you can try over gear a motor at least 3 to 4 tooth but be sure you only apply 60% of throttle at the straight. only use full throttle when you need to overtake the other cars but you can only do this once or twice in a battery pack run. with proper throttle control, your motor should run cooler so do your battery pack.
that might be a problem for some of us...used to mash the throttle and coming to straights...if you said only 60% throttle, i think you could use some blocks to limit the travel of the throttle...hehe!!
Old 11-15-2001, 03:18 PM
  #2197
over gear's Avatar
Trader Rating: 17 (100%+)
999: what's wrong with your TC3?
over gear is offline
Old 11-15-2001, 08:49 PM
  #2198
fai
Regional Moderator
fai's Avatar
Dtm: So, will you go directly from home tomorrow ... I wonder if you can kindly pick me up also at hong kong side...
fai is offline
Old 11-15-2001, 08:56 PM
  #2199
ernestf's Avatar
OG, i have killed two ESC and 4 motors on my TC3 in 1 year. That's never happen to my other cars.
ernestf is offline
Old 11-15-2001, 09:12 PM
  #2200
TFR
TFR's Avatar
maybe differnet weather would effect the car??
in the states or whatever...many ppl use TC3...
TFR is offline
Old 11-15-2001, 09:37 PM
  #2201
dtm
dtm's Avatar
Albert is driving tomorrow, PM me with your mobile no and I call you tonight!
dtm is offline
Old 11-15-2001, 09:38 PM
  #2202
dtm
dtm's Avatar
For the sake of your ESC and motors I would say get rid of the TC3
dtm is offline
Old 11-15-2001, 09:41 PM
  #2203
dtm
dtm's Avatar
Strange.... I've never noticed this before, but you are not allowed to post more than one post in 30 seconds!!! I will just have to type s......l.....o.......w.......e.........r!
dtm is offline
Old 11-15-2001, 09:43 PM
  #2204
TFR
TFR's Avatar
OH....i thought it was one "whole" minute....
TFR is offline
Old 11-15-2001, 09:44 PM
  #2205
TFR
TFR's Avatar
ha, dtm trying to go for 1000 post....
TFR is offline
